Are you asking how to get more volts? You have to mod your 3.3v line because your vdim is your 3.3v line -.15v hence the 3.15v. 3.3-3.5v should be neough to pull 250 tight.
I was wondering how stable the voltage is though. Because my 3.3v line fluctuates slightly, so I was wondering if you saw any vdim fluctuating by grounding pin6 rather than using a vr to lower the max voltage below the low point of the fluctuation.
