Well here's my entry into the fun. Still trying to figure out the timings and everything. Pretty good for 2 days of testing with an Intel after spending the last 6 years with AMD.
Hey guys,
Just got my e6600 and p5n32-e plus installed. Everything is working great, except for the fact that I am unable to change the Vcore. Any voltage I select in the bios yields a Vcore of 1.4v...unless I jump up to 1.60 Vcore, which then yeilds 1.55.
I have tried the vdroop mod, and while that has eliminated any droop, I'm still not really able to choose much in terms of Vcore.
Any ideas?
update the bios to 0902 BETA or 0903 Official..
OR
flash it back to 0302 =)
Those are the only Bios versions where you're able to freely control the VCORE =)
Enjoys!
Codeman's got the plus version so he'd need the 0602 Bios. You're talking about the non plus :)
What bios are you using? did you also do the Vcore mod?
if your running anything less than 0602 get it here ftp://ftp.asus.com/pub/ASUS/mb/socke...0Plus/0602.zip
Anyone try running DDR2-1000?
I've set my mem to 1000 and fsb to 1600 (4:5 effectively).
I've been trying to mess with superpi 32M the last few hours but I'm having problems. I've tried vNB all the way up to 1.7 but no luck.
The 8000HZ's I have are rated up to 2.4 volts but even at 2.4, I can't get passed 8-10 loops. :(
yeah. i tried up to 2.42 but no go.
i just tried 2000/1000 linked and 2000/1000 unlinked and both appear to work! :woot:
however, 1600/1000 unlinked DOESN'T work :stick:
that just doesn't make sense to me. i guess i will have to keep tweaking. this board has lots of voltage options and what not that is making it difficult but fun!
anyone else try 1600/1000 unlinked?
I've tried vNB all the way up to 1.7.
1.7 will make it through about 8-10 loops before my computer reboots.
I was able to do 2000/1000 linked and unlinked with vNB at 1.6 and vdimm at 2.35.
SB I've kept at 1.55 and vTT I keep at 1.4-1.45.
It's just strange that 1600/1000 won't work (which is like running 4:5 on 965/975) but 2000/1000 (which is running 1:1 on 965/975) does.
I thought that 1:1 was always more stressful to a mobo than 4:5 (assuming same mem frequency).
anyone using a tuniq tower with this mobo...what chipset coolers will fit with the Tuniq...THANKS (ie. Thermaltake CL-C0034)
that'll work too. one thing i've noticed is that even with the 159cu, the chipset get HOT!
my NB only needs 1.55 volts but I'm watercooling it. asus probe reports even at 1.55volts it will spike up to 1.61 volts. I suggest people do the vcore and droop pencil mod for this board to run lower volts.
edit: I've managed to get stable with only 1.5v on the NB now.
i think that's a good suggestion.
i'm not comfortable with a pencil mod though. i'd prefer pulling out the soldering iron and doing a droop mod with a VR. :)
All right, everyone with this board, please try 1600 / 1000 unlinked 4-4-4-X with 9x mult.
Then try 1800 / 1000 unlinked 4-4-4-x with 8x mult.
Then try 2000 / 1000 linked or unlinked 4-4-4-x with 7x mult.
I want to see if anyone else is having issues with the 9x mult and 1600 / 1000 unlinked as 1600 / 1000 is the only one that won't work for me.
I think 8x is the sweet spot for my chip. Currently working on 1800 / 1030 right now 4-4-4-5 with 2.35 volts on mem.
I just received a P5N32 SLI Plus and a q6600 from NewEgg. I can't get the FSB over 1200. When I received the board it came with the 0302 bios, I flashed it to the 0602 which gave me the same result. I've tried several different types of memory but no matter what I do, as soon as I set the FSB over 1200 or so, I get to the boot screen and it locks up and the only way I can change anything is to do a manual CMOS. Is it possible I have a defective motherboard? Does anyone have any suggestions.
