doesn't matter which subtiming, just change one, cause it seems, they aren't saved, if you leave them as they are - even if they are set manually to whatever you want.
i for instance have them like this:
tRC 22, tRFC 35, tWR 5, tWTR 8, tRRD 5
now if i restart my computer, it wont POST - don't have a speaker so I don't know what beep codes I'm getting, but the signal to the monitor goes off and i have to hard reset the system so that ASUS CPR kicks in and sets the timings to some safe value. In this way I'm able to go into BIOS and change something under subtimings, for instance tRRD from 5 to 6 and do a save&exit and the PC boots just fine. If I don't do this, I can restart for 100000000 times and not once will it boot up. So I assume, everytime you do a save&exit from the BIOS, the subtimings just revert to the auto values in next booting process, if you don't change at least one of them in that last visit to your BIOS before you did save&exit.
clear enough now? :)
