I said to people here on the forums that reports are starting to come in, but they rekon it is user error.Quote:
Originally Posted by palese
Yes i have tested the ram in P5B and DQ6 worked for months.Quote:
Its always user error until it happens to them.Quote:
Originally Posted by X.T.R.E.M.E_ICE
I have another problem with this MoBo, i cant install Windows. In the middle of installation (When network is installing) installation stops and some notice about missing files on CD appears. I am crazy from this.
Wrong. Unless it becomes a widespread issue, it remains user error :fact:Quote:
4 or 5 people isn't widespread.
clean or change the install diskQuote:
Originally Posted by OBR
if that fails try a differant rom drive
Also check ur cpu mounting as wellQuote:
-tam2-
Disc is clean and OK, i installed yesterday another PC from it. Installation crashes on the same point ... it seems like windows installer does not see my CD-ROM..., i tried everything - change drives ... and no success.Quote:
Originally Posted by bazx
That's nearly always a RAM issue.Quote:
Either RAM's not stable, or slot is bad.
Checked your timings/vdimm?
I am not sure, that is a RAM issue. They are good modules and on P5W DH works great, now i have timing 15-5-5-5@800Mhz...2.1VQuote:
Originally Posted by -n7-
Would I be right in assuming the new E6850 E6750 E6650 chips will all have much lower multipliers because of the new 1333 FSB than their current counterparts and therefore not be as useful for overclocking?
For example the E6600 has a multiplier of 9 (9 x 266 = 2.4GHz) but the E6650 will only have a multiplier of 7 (333 x 7 = 2.33GHz)... wouldn't that make it far less attractive for overclockers?
http://www.digitimes.com/mobos/a20061123PD209.html
7x multi cant be good.
This eVGA MoBo is the worst i had. Some problems i have now:
1. If i typing on keyboard , system is beeping and when beeps some letters are missing - PS Keyboard not working properly, i have problems with CAPS LOCK too ... my letters are BIG or SMALL and does not matter then is Caps Lock actived or not ..., my keyboard is typing itself, if i dont touch to keys - some lettters are typed.... !!!!!!!!!!!!
2. PS2 mouse is unstable and is jumping ...
3. I still cant install Windows, in halfo of installation my DVD-ROM is missing and installatin ends ...
4. nTune does not work form me in my regional settings ...
5. This is the HOTTEST MoBo in ten years ...
Sorry for lot of mistakes in text, but i cannot to control my keyboard ...
I wish to say again, since I have been misquoted, this board did not hurt my ram. I have yet another new board from Compusa and it works perfectly in all regards. Installed easily, overcolcks easily, no probs at all. Bad boards exist from all manufacturers. It was my misfortune to get three in a row. I'm certain my x6800 will break 19,000 3DM 06 this weekend.(maybe) Bob
Easier than I thought.http://service.futuremark.com/compare?3dm06=664098
My new BFG replacement is not seeing DVD as well.Quote:
Nforce 680i.....
http://img241.imageshack.us/img241/6...shot154dt9.jpg
975X....
http://img223.imageshack.us/img223/5...t097aw8ou4.jpg
looks faster
nice :)
hmmm this is E6700 on P5W DH
http://fileshosts.com/intel/Asus/P5W...e_11000_tn.png
[QUOTE=Dumo]Nforce 680i.....
Whats Smartguardian suport 680i SLI chipsets?
prolly because he's running 1:1 on 11xmulti hehQuote:
Originally Posted by eva2000
He used 975X with SGQuote:
here is my run on 965 with no ram tweaks at all.
http://img152.imageshack.us/img152/8881/4vp5.jpg
little off topic.....
palese your rig is almost identical to my new build could you please post your current BIOS settings for your FSB, multi, vcore & RAM ratios & load temps
I would be very grateful as this would give me a good starting point to my overclocking
Hi mda96bjh I can't give you them until I get a working board:) I had a bad eVGA board so I did an RMA, now I have a bad BFG board:D The BFG did good until I flashed to the latest bios. If you have the BFG do not flash to the latest beta bios:fact: I had no keyboard issue with the shipping bios and now I do:eek: In the shipping bios I could run my corsair @ 1T by default but now no way:confused:Quote:
Originally Posted by mda96bjh
Let me get yet another board this week:woot: and I will pm them to you :)
I can see nvidia sacking a few R&D crew as i keep hearing some people have had to RMA more than once.:slapass: :slapass:Quote:
