Originally Posted by ted34
Have tried the 0005 bios and the 0408 bios. Had problems with 0408 booting so went back to 0005 which seems to be the best.
One problem though is trying to get my memory stable. Cant get them stable past 482mhz @ 4,4,4,12 with 2.2v in bios (2.3v in windows). If i up volts to 2.25 or 2.3 it makes no difference and ai booster reports weird values then so not sure if its working. If its not mem volts causing probs what is it:
Cpu is at 386 x 9 which is stable
Ratio 4:5 to memory (gskill 2gb 6400 hz kit)
All board volts are at mimimum
Memtest in dos immediately crashes if try and run 3,4,3,8 @ 390mhz at 2.2v which also seems weird. Maybe memory just wont do this but would have thought if it can do 482 at cas 4 it could manage cas 3 at 390mhz
