New Member with an DFi Expert MB/Opteron 170 and Questions
I want to thank everyone for the wealth of info that has been posted on this site, and hope to continue learning from you. This is my first serious attempt at building an overclocked system.
I have been building up an AMD Opteron dual core system based on an Opteron 170 processor, and have found some of my results to be quite different than expected.
I am getting better overclocks with low voltages than with what voltages are often used here. But if I up Vcore to the 1.4-1.45 V level, I am only stable to 2550 MHz range, and CPU temps rapidly hit 49-50 C (using Smart Guardian). I suspected a poorly seated CPU or a bad job of applying the AS5 was to blame, but redoing it (with a very thin layer) made no difference.
My Opteron 170 seems to really hate higher temps, with anything above a 46 C reading in Smart Guardian causing errors. It wasn't until I moved everything into my new Silverstone Temjin T07S case (much better cooling than my old Antec Sonata) and dropped my Vcore that my OC attempts met any real success.
I ran AMD MaxTcase yesterday, and it told me my max Tcase temp is 53 C.
I have been able to run dual Prime 95 at 18 hr + stability (I stopped it then, no failure) with CPU and PMW temps of 41-42 C. My chipset temp is only 38 C, perhaps due to my running a Zalman chipset heatsink. (all temps off of Smart Guardian).
My opteron 170 seems quite efficient, giving me 2700 MHz for only 1.350 Vcore, but I was hoping to reach a stable 2800 MHz so I could maximize my Mushkin XP4000 Redline RAM (set on an 11 divider). This RAM is stable to 257 MHz with current settings.
I noticed my Vantec Stealth's 470 W PSU's voltages were starting to fluctuate (consistent undervoltage) at my 2700 MHz overclock, so I am replacing it this week with a OCZ Powerstream 600W PSU before going further. I hope the extra power and stability of this PSU will allow further OC improvements on air.
I have several questions:
1)Is my particular version of the Opteron 170 (CCBWE 550 UPMW) more suitable for a water cooled system because of its apparent temperature sensitivity?
2) Should I "pop the lid" off of my processor, and if so, what are the likely benefits/potential risks? Keep in mine I am using a Zalman CNPS9500LED heatsink, and it is not particullarly light.
3)If I eventually go with a water cooled setup, do you think my Opteron 170processor will handle more volts and provide better overclocks, or am I better off going with an Opteron 175?
Any input or suggestions on how to proceed will be greatly appreciated.
