Well after some minor tweaking and pushing I got a 27 sec Super Pi 1m. Done with OCZ PC4800 elite plat.. great mem btw. does over 300 stable at 2.5-3-3-6.
http://www.xtremesystems.org/forums/...id=39940&stc=1
Wich conifg gives best redsult with 146 CABYE 0540 and DFI lanparty ultra-D.
BH-5´s 2x512 @ 260 htt 2-2-2-5 1Tand have a divider so that the CPU is going 310X10.
OR
OCZ pc-5000 2x512 310 HTT 3-4-4-10 2TWith no dividers
Originally Posted by Wiker
bh-5@260.......2t kills the OCZ
So i won´t loose any performance using the dividers?
ihs are on both has the temps are low, the 148 loads @ 41C and i dont think taking the ihs off with lower my voltsQuote:
Originally Posted by phadeout
What to you think about 144 CAB2E 0542EPMW? Is it any good, i´d really like to know.
the 0540 cab2e is hit or miss, some only get 2.6ghz some have maged 2.8ghz and is similar to a cabge imo
No, the 144 ~ 2.8ghz and the 146 ~ 3ghzQuote:
Originally Posted by tatts
146 CABYE 0540FPBW, +16h StressPrime 3050MHz 1.45V TT BigTyphoon
ok, show me some prime stabe 144 cab2e's doing 2.8ghz plz without ridicolous volts, most do 2.6ghz - 2.8ghz and have only seen 2 over 2.8ghz but not sure they was prime stable
Nice ex you got there what batch? :) ,and idle /fullload temps.Quote:
Originally Posted by Dani
time for some 2GB fun http://i4memory.com/showthread.php?t=1721
http://www.fileshosts.com/memory/ocz...C400EB_009.jpg http://www.fileshosts.com/memory/ocz...C400EB_022.jpg http://www.fileshosts.com/memory/ocz...C400EB_025.jpg
Opteron 146 CAB2E 0540FPMW with Corsair Hydrocool 200 water cooling
DFI NF4 Ultra-D R.AD0 704-2BTA
1x BFG 7800GTX with HeavyH20 modded bios @500(552)/1350 and 81.89 beta drivers
1x 160GB Seagate 7200.8 SATA NCQ hdd
Liteon CD-RW Burner
Floppy drive
510W PC Power Cooling SLI PSU
10x 306HTT = 3060mhz with 180 divider
@278mhz 3-3-2-5 7-14-2223 at 2.66v
CPUZ Validated:
http://valid.x86-secret.com/show_oc.php?id=50787
3dmark2003
@500(552)/1350 = 19,954
http://service.futuremark.com/compare?2k3=4406188
3dmark05
@500(552)/1350 = 8,905
http://service.futuremark.com/compare?3dm05=1448541
Super Pi 32M v1.40 mod
http://www.fileshosts.com/DFI/NF4_SL...rpi-32m_tn.jpg
Pcmark04
Score = 6,238
Memory = 7,308
Thanks!Quote:
Originally Posted by Lastviking
Batch number does'nt mean anything, at least not how much it gonna OC :fact:
But 0357
FULL load +43ºC, ambient temp ~23ºC (+-1ºC)
http://premium1.uploadit.org/Kameleon/prime.pngQuote:
CAB2E 0540 FPMW. I know it's not been priming for very long there, (I've been running Muon1 for more stability testing instead of Prime recently) but this chip is 100% stable at these settings, no matter what I throw at it. Hit an HTT limit now though, looking for a lot more out of my 146 :)
here is a nice stability shot with my ram at 290mhz... some rather excelent timmings. I will be working on tightening them up relatively soon.
http://www.xtremesystems.org/forums/...id=39944&stc=1
[QUOTE=dogsx2]Yes mach 2 but look at the Vcore, IMO most important reading for 3 Gig no matter the coolingQuote:
Originally Posted by alpha0ne
I have a 0540 CABYE FPAW from zipzoomfly. 1 day old.
http://home.earthlink.net/~sgallai/i...opteronoc1.JPG
just doing quick testing. but like the other FPAWs posted here such as the one from dnottis, I do not think it can do 3.0ghz.
at last with Vcore 1.7 V , 18 C room temperature i can push my CABYE 0536 GPMW to run super Pi 1 Mb at 3 Ghz ,not good result but i am happy can run super Pi 1 Mb with 3 Ghz :)
<edited:sory mine not CABGE but CABYE...i wrote this post before i sleep :D >
http://img247.imageshack.us/img247/411/300x106yp.jpg
stay away from 1.7v i think too much voltage.
sorry but sp2004 for 1minute 30secs, my 146 can run it for that long @ 3.3ghz & is stable for benching gaming etc on 3.2ghz but fails prime after 5hours & now peed off, have to raise to 1.65V i think so i can brake 34,000 :slobber:Quote:
Originally Posted by Kameleon
http://img439.imageshack.us/img439/2...mark8nh.th.jpg
Only wanted to know the batch so i can se if it are a close brother to my 0239 :) , It seens to that the 400-500 batch are not good like <-400Quote:
I suggest you look/read this:Quote:
http://www.vr-zone.com/index.php?i=746&s=3
I think there's no sense in talking bout low batch numbers.
The cpu are sorted, tested/binned to be ie. Opteron 146, but from where on the wafer they came, I don't see how we can know.
Regards Monge
OK...so what would you like to see to prove to you that not every CAB2E is capable of no more than 2.8, or whatever ridiculous statement you made? I've got time, it's just a matter of running the benchmarks. I said I knew it hadn't been going long, that's because I was using my idle CPU cycles for something useful before I saw your post :rolleyes:Quote:
3DMark loops? Super-pi 32M? Prime (though prime is what sp2004 runs, so it'll be just as stable)? You name it, this chip is stable like this (317x9 @ 1.55v).
first off, the guy said any 144 cab2e can hit 2.8ghz stable which is bs, ive seen alot stop at 2.6ghz and not many go past 2.8ghz stable (read before retaliating) :rolleyes:
stable imo is prime95 or sp2004 for 8hours+
no offence but you make me laugh, you post on everything forum ive seen going on about these low batched number opterons your getting as if there going to get you a world record because your tech friend said low batch = good clocker, best bet is to just wait and see ;)Quote:
[offtopic]
My best Venice 3200+ had batch number 1133, did 3.2GHz Prime95 stable for +11h.. :stick:
Other 5 3200+ had low batch, did'nt even near 3.2GHz Prime95 stable
[/offtopic]
