they probably changed how much LLC is applied at auto, or even tuned the levels a bit.
BTW if you want your BLCK at 100.00, set 100.2 and it will give you 100.0.
Just curious, anyone tossing an ivy in one of these to see how she runs?
Did anybody tried a 3770K on the P67A-UD7-B3 (bios F7 seems to support Intel 22nm CPU E1 stepping)? Any downsides on still using the "old" UD7-B3? I was thinking about an upgrade... but i will wait till i know it's really running ok :)
Looks like we'll be stuck with a 39 multi on the P67/Z68 boards with Ivy bridge http://www.legitreviews.com/article/1917/1/
wait a week or next week and a new BIOS will come out.
I have the exact same issue! :shrug:
All drivers installed. But Windows 7 keeps telling me there is an unknown device on Port#/Hub# 4/7.
I unhooked all devices from my PC and after a reboot, the 'unknown device' is still present and being detected.
Is there anyone that knows which device/driver this is?
[Edit] 17-08-12 - Problem solved!
http://forum.giga-byte.co.uk/index.p...ic,9502.0.html
Hi, thank you in advance stasio for your many posts about bios. I need litle help, because my english is realy bad, im not 100% sure how to flash this modified Bios from B3 revision to my B2 revision UD7. I have F8X bios now, is it necesary to use oficial F8 bios? Can i flash this modified bios in Qflash? or i need MS DOS utility? THX
As stated in my post,
first flash from B2 to B3 must be done with @BIOS (or with FlashSpi in DOS) .
Once you flash to B3 BIOS, next flash can be done with QFlash (you can flash strait to latest F7).
OK, thanks :) But one more question, if this new bios is bad for me, and i want go back for my F8x, can i use same way? first time use @BIOS or FlashSpi and flash back F8x ? or i need some special utility or another :banana::banana::banana::banana: ... Thanks in advance
Where you found my post,there should be reverse BIOS......B3=>B2 also.
Also posted on TT forum:
B2=>B3
http://91.121.148.119/downloads/BIOS/P67aud73.f3h1
B3=>B2
http://91.121.148.119/downloads/BIOS/p67aud7.f8f1
Same first flashing for both.
Thank you stasio! it work very well!!!
:yepp:
just started with a weird issue it randomly reboots even from in bios and normally i get about 5 pulses about a second apart then it restarts the pulses light the lights up in the case for a second and the fans twitch , going to strip it all down tonight i have tried a different gpu and tried each ram stick single and its the same
