should be the numbers by the first pci slot.Quote:
Originally Posted by April
last 3 or 4 numbers on first column second line.
It's R.A00.Quote:
Originally Posted by likewhoa
before that, it's 3 or 4 numbers :D
Sorry... full # is: NF4E91-200 R.A00Quote:
Edit: Priming at 292x10 @ 1.41v :D
I'll do it tonight. Keep in mind I have a DFi CFX3200. It's easier to keep stable than the SLi boards. What do i get when i win?:slapass:Quote:
Originally Posted by Peter949
Received my Opty 165 today.
Stepping:
LCB9E 0636 APMW
:confused:
Let us know how it doesQuote:
Originally Posted by All_Star
What are you waiting for..........pop her in and let us know how she clocks! :slapass:Quote:
I found this x2 4200 LCB9E 0636 BPMW on DFIStreet............296x10 1.425v, not bad :)
http://www.dfi-street.com/forum/showthread.php?t=67353
so B9 memcontrollers are about to float around now too..
someone PLEASE try these under the cold!
Hey i asked the same before 2 days.I think i am first in here:p: .I've started with 1.4v to 2.7.Now I'm to 2.9 with 1.5v but i have problems with my memory sticks.They cause stability problems when they are at 265mhz...I see if i can solve it so to keep on o/cing this new Opty.Keep us inform how you doing with it.Quote:
This thread is all about ocing the CPU, so just keep the memory below 250mhz and focus on the CPU. When you've found the CPU's max, go tweak the RAM speed/timings. :)Quote:
Originally Posted by DevilCry
U have a point there.I ll be happy to stabilize at 2.9 cause my memory tops at 265 with 3-3-2-5.Before at the same o/c with Opty 148 Ν' San diego 3700+,everything was normal and stable.This is my first to attemp o/c with dual core.
3-3-2-5? your sig says HZ which is UCCC ram (3-4-4-8 stuff)... those 3-3-2-x timings are common with the ZX and HX (infenion BE/CE-5/6 IC's).Quote:
Yes i know.Strange thing but true.Have a look here
Current settings:Quote:
Originally Posted by G4h4o8s6T
9x300 = 2700mhz @ 1,4v
RAM = 300mhz 2,5-4-3-6 (1:1)
3D stable, think I'll just keep it at this settings :p:
Before you ask: I don't care about prime / whatever. If my games are 100% stable, it's ok for me.
co0l.Got the same reaction(same stepping).Push it little further.
Push it.. we want to know if it make 3.0ghz :)Quote:
Nah, chip is not that good :mad: I can't boot Windows at even 2900. But I don't care, 9x300 1:1 is nice, I'm not a benchmark geek :p:Quote:
Originally Posted by Lastviking
can u post a cpu-z screenshot of the memory info stuff. not the speed/timings tab but the other info (brandname, IC's, SPD).. yeah, the SPD tab. thnxQuote:
thx for info.Quote:
I removed the IHS on my 3.0ghz opty 170 this morning. It had been running orthos over night at 1.325 + 112% (1.484 ~1.456 in windows). Load temps were according to core temp at 49/50 degrees. After removing the IHS my temps dropped 10 degrees on both cores. Last night it would run 1m superpi at 302x10 but orthos would stop after 1-2 seconds. Running orthos right now at 302x10, same vcore as before and temps are down to 39/40 degrees according to core temp :woot:
Here u areQuote:
Originally Posted by biohead
http://img226.imageshack.us/img226/4785/riiy5.th.jpg
Finally got my Opty 165 today!
I was really hoping for a good stepping since the last few cpus I had were merely average in terms of overclocking...
so I quickly opened up the box and there it was :
http://www.dan.he-hosting.de/files/cpu.jpg
Needless to say I was very happy! :D
It's running Orthos now @ 311x9 / 1.392V :
http://www.dan.he-hosting.de/files/orthos.png
Temp difference between cores is ~6°C. (42/48°C @Orthos)
:banana:
jack pot man!Well done.
your going to love that stepping ;)
