http://img120.imageshack.us/img120/2...004124v3ky.jpg http://img460.imageshack.us/img460/9...01385690in.jpg
:banana: :banana: :banana: :banana: :banana:
With TT BigTyphoon
Did'nt see +24h becouse we had power cut in house :(
This was taken before I went to job
http://koti.mbnet.fi/dani69/DFI%20nF...4Vcore_AIR.gif
http://xtremesystems.org/forums/atta...id=39891&stc=1
Both are doing:
http://xtremesystems.org/forums/atta...id=39892&stc=1
Sweet~! :D
hey guys..
anyone knows what a 148 CABYE 0540 can do on water ??? Newegg apparently has them now.
:banana::banana::banana::banana:ing newegg is :banana::banana::banana::banana:ing crazy 230$
Did just recieve my 146 from www.komplett.se
146 CABYE 0540FPMW sweet :D I hope 3ghz on air.
hey man, nice OC! what batch numbers? i hope i will get my two CABYE 0540 FPMW with batch 0001 and 0230 tomorrow :slobber:Quote:
Originally Posted by Jupiler
the 148 is a waste of time imo, my 146 CABYE 0540FPBW is stable 2.8ghz stock V, 3ghz 1.45V & think 3.2ghz is stable 1.6V (still testing) were has my 148 CABYE 0540FPBW needs 1.65V for 3ghz
Got mine today! Will be testing out budget oc with BioStar Tforce6100-939, some SuperTalent CS2, ZALMAN CNPS-7000B-CU LED, WD 2500KS, and X-Qpack SFF Case. :banana:
CABYE 0540 FPAW from www.chipsandmemory.com - will have to call or email to setup, he has only a few more currently.
:lsfight:
Tatts,Quote:
Originally Posted by tatts
Do they both have the IHS removed? It's possible the 148 is just as good, but has bad heat spreader contact compared to say perfect contact on the 146...
I'm having a few problems with my Opteron 146. Not sure if it's something I've missed in complete n00bness or what the problem can be. Rather than double post, you can find thread here http://www.xtremesystems.org/forums/...ad.php?t=80129 and I'd be grateful for any advice you can give.
Hope this is ok.
Thanks.
Originally Posted by KenRico
So far mine is stable up to 2920 with Big Typhoon.
http://www.3dxtreme.net/other/CPUS/O...-12hrprime.jpg
http://www.3dxtreme.net/other/CPUS/O...W/IMG_2303.jpg
Be sure to let us know. I want to get nearly that exact same configuration in the future.Quote:
Got a CABYE 148 0540 FPBW & DFI Lanparty UT NF4 SLI-DR today from Newegg. OCCT passed 2860 @ 1.36V (max temp 43). Will keep pushing.
Anyone know the solution to my CPU-Z throwing up a message that many of the information will not be available? I have to close and restart it and then it shows everything.
Also when I start MaxTCase, in the "maxtcase" field it says "could not locate the on-die memory controller". Anyone know the solution to this?
This is what I got after I redid my fan setup on my water setup.
http://www.johnshim.com/forums/xtrem...ft0530apmw.jpg
Stable point before going further...
http://www.xtremesystems.org/forums/...id=39929&stc=1
I'll install en external probe on the CPU to measure temps, because I think they're raising very quickly, and I usually don't trust internal diodes...
Question to you opteron overclockers. sorry if it is a dumb question but ive been very interested in this boom of opteron overclocking. If i were to overclock one of these to say 2.8ghz (fx-57), would it technically game like a fx-57 or would it be different in any way? I would only buy one if i knew that it would game according to its clock speed. Thanks very much
#194 and 434.Quote:
Originally Posted by SPivX
This one is the 434.
Wasn't completely stable at 1.456V though.
Prime errored after 3 hours.
Gave it 1.472V and priming for over 3 hours now. Will let it run for at least 12 hours today.
Just got my 146 today and here is where Im at. I will post a picture of the stepping in a bit. I tried up to 1.475X113% and was not able to get it to even boot at 3ghz.. 2.95ghz also seems out of reach. Really a pitty as I want to run my ram 1:1 at 300mhz.. ohwell.
http://img394.imageshack.us/img394/2121/29ghz1ji.th.jpg
http://www.xtremesystems.org/forums/...id=39930&stc=1
On an identical setup with same dividers ect it would be exactly the same as an FX57 ;)Quote:
Originally Posted by Starman
First results with me 146 cabye 0540 fpmw.
http://img.photobucket.com/albums/v2.../33001M800.jpg
http://img.photobucket.com/albums/v6...00small800.jpg
http://img.photobucket.com/albums/v2.../34501M800.jpg
http://img.photobucket.com/albums/v2...M3300small.jpg
That is the best I have ever seen loc.o , congrats :toast:
Which board are you using :)
[QUOTE=alpha0ne]That is the best I have ever seen loc.o , congrats :toast:
:confused:
it s with a Mach II :slap:Quote:
Originally Posted by alpha0ne
Originally Posted by Pt1t
It must be a time zone thing in OZ :D
