Same here :)
Guess it's time to show some real :banana::banana::banana::banana: :D
Maarten-NForce' BlackBox ™ 2000+ CFM Fan:
http://www.imagehosting.com/out.php/t1699751_BB1.JPG
@emon
What cooler is that?
Accelero Xtreme 8800/2900
http://www.arctic-cooling.com/vga1.php
ive heard that the backplate coolers like that help get rid of radiated heat that just sits around the chips
i'm using a gigabyte dq6 which comes with crazy cool backplate and i agree that it does help cool the rear of the motherboard & cpu down. IFX-10 on the other hand has some terrible thermal pad that doesn't transfer much heat to the headpipes at all. If you could test it out with some ceramique you maybe get better results.
http://i223.photobucket.com/albums/d...ercard_001.jpg
My x1900 Mastercard with Accelero S1. :up:
Wow very nice deepsilver, you come up with new things almost everyweek :)
is that a 120mm YateLoon? :)
last question, is that your car in your sig? :D
Deepsilver - very nice cooling solution!
Cabbspapp - more photos please!!! Looks very good so far!
Disrupt: Come on guy!!!
here's my contribution... still on air, waiting for water :)
got bored yesterday and did some wire managing
and sorry for night pics only, will do some proper ones later
http://img141.imageshack.us/img141/6475/p1010029wh9.jpg
http://img152.imageshack.us/img152/8547/p1010030cr0.jpg
http://img152.imageshack.us/img152/8248/p1010032yl3.jpg
http://img183.imageshack.us/img183/8215/p1010036gy0.jpg
http://img183.imageshack.us/img183/6813/p1010037bh3.jpg
http://img168.imageshack.us/img168/6421/p1010040ig4.jpg
as you can see, there's still a lot to do, but it's getting there :up:
Re: the 80mm Tornado on the ND-1 (above) ...
Load temps went from 60C to 45C.
Here's the temp review: http://www.xtremesystems.org/forums/...d.php?t=184484
testing out the smaller 92mm heatsink for a friend.
http://h1.ripway.com/Ar3s/IMG_0444.JPG
T.R.U.E high pressure mount mod:
http://resume.jbhfile.com/temp/pressure_preview.jpg
Got me three degrees with that ...
^ i cant wait to see what it is.
new pics of my new build will get posted tonight :)
just got my new case fans in and Ultima 90 S-clip.
Yes, it's a 120mm. :up:
And no, my x1900 in the sig is a regular XTX, no mastercard for crossfire. ;)
http://xtremesystems.3d-nexus.de/Gig...900-XTX_01.jpg
http://xtremesystems.3d-nexus.de/Gig...900-XTX_02.jpg
Thank you! :D
maybe because tread name Air Cooled Gallery :D
hmmmm
not that great, but this is the smaller heatsink. Its helping to cool the HR-03GT at the same time so thats the problem. Otherwise it would be much lower in temps. I'm waiting for the 12cm fan variant. I have to say i love everything about Noctua package presentation. They got adhesive washers to prevent the brackets from shorting / scratching your motherboard. They got a rubbery backing for the backplate to do the same thing. The fan clips can be adjusted so that if you ram cooler is blocking you can move the fans above the cooler.
Note to self : I'll try to take better shots with a tripod that time.
