Took so much time (don't asky my girlie about it lol) hope the threadstarter adds it to the first post... will update it once new batches appear...
Temps seem high huh? It is currently 100F outside and 78F inside. AC keeping us cool!
Here is a Short of mine CPU/OC on AIR (ThermalRight 120 EXTREME)...
http://www.imageshack.gr/files/tif3cynibwb6own723sa.jpg
http://www.imageshack.gr/files/31v7sy5xmlxjznrscqdz.jpg
http://www.imageshack.gr/files/3a2zdyv3rcxdc7uss0hg.jpg
http://www.imageshack.gr/files/pha57x97u6bc6ppas4ft.jpg
http://www.imageshack.gr/files/ks1bg0mghw79iq96xzrn.jpg
Rest info here in ENGLISH ----- http://www.xtremesystems.org/forums/...d.php?t=186318
Here in Greek Language ----- http://www.thelab.gr/showthread.php?t=50334&page=4
Enjoy... :up:
^^^^ thats simply a insane chip.. wow ...
Low Vid but High Full Load Temps if readings are correct....:D
Next week my Watercooling will be ready for action and hope for much better OC... :up:
BTW is was just Lucky...:ROTF:
not just lucky........:D:D
and it`s your first C2D...
Noob Luck i think.... :rofl:
Dagalidis, Tjmax in CoreTemp isn't correct, it should be 95C.;) So your temps would be 10C lower.:)
hmm some benching with my new E8400 never saw this batch before
Q804A249 wafer XXXX817 :p:
4ghz 1.20v
not as good as Dagalidis one but sounds promising
me happy lol
and better than my actual xeon Q746A534 1.29v 4ghz load( same vcore than former xeon Q807A01 but better temps )
http://img398.imageshack.us/img398/4797/q804yz8.jpg
i dont understand how is it possible to have it at 4ghz with only 1.2v:(:confused::shrug:
Run orthos longer! :p:
I pasted 35 minutes of orthos with 1.200v, it took 1.21v to get it stable for 4+ hours.
anyone ever tried Q744A? i search here but no luck :(
lol ThatGuy ! that chip seems very similar to yours
failed prime after 45 min small ffts , should have run large or blend :rofl:
Anyway , it should be stable with less volts than my current xeon Q746
( 1.29v )
So you miss xeons Q807a091 and E8400 Q814A015 :p:
http://www.xtremesystems.org/forums/...&postcount=179
unfortunately I sold it lol
I changed my e8500 cpu gtl reference to 0.67x, and now it boots only if underclocked before this i have 9.5 x 450 @4.3 vcore 1.32 no with no problems. I have tryed 3 motherboards: Maximus formula, Maximus rampage and p5w dh deluxe, same problem with each one. LCD poster says det ram, I have tryed with 3 different sets of memory.
i tryed change volts and everything but no post even stock clocks with 300 fsb i can boot
Dagalidis, Wow are you nuts????/?, having such a Golden CPU and saying your JUST lucky.
I would kill to have that CPU.
hmm have to fine tune bios settings
yesterday ran 45 min prime small with 1.20v and today failed in less than 5sec with 1.21v :ROTF:
But I succeeded raising my max fsb air cooling comparing to my xeon and temps are quite fine :D
http://img223.imageshack.us/img223/1...4p13kc8.th.jpg
Valid 4.8 ghz 1.56v air
It failed faster with higher voltage, :confused: :rofl:
I want to bench mine above 4.5Ghz so bad, but i can't seem too get above 512FSB. It will completely lock up after a couple minutes into windows. I have raised my FSB, and MCH, i know its not my ram... :shakes:
:help:
Well most peeps look for how batches perform, you can do with the list what you want, but most users can quick reference the batch with some results ( if we have any ofcourse)
I'm planning to add any 45nm I can get my hands on... peeps can pm me and I will try to keep the list as updated as possible...
