Yeah cheers Pete, that is our usual UV dye but having said that the new pre mixed Feser One is looking good as well :)
His UV lighting is unobstructed, up and close :D
Talk about a Nice Case! And Nice Build! Great Job coolmiester!
Very nice job with the case, it as a very clean look. :clap:
It also has some interesting details. ;)
Congrats
What a mess! Can you find the pump? :D
Yup, its behind the IDE cable.
Time to add my riff-raff to the neighborhood...
http://i80.photobucket.com/albums/j1...0/newwater.jpg
Fuzion block, great pump, 2 rads, orange fans, everything very clean...what can I say? :toast:
Most of you remember my old setup with the Lian Li PC7B & Tri-Rad. That was a little OTT so I decided for something a bit on the conservative side.
So I went air, and lasted about a week before I had a major craving for water again. One thing I'll say, when you've gone water there is no turning back.
http://upload.overclock3d.net/get.php?id=2056&view=1
http://upload.overclock3d.net/get.php?id=2058&view=1
http://upload.overclock3d.net/get.php?id=2057&view=1
http://upload.overclock3d.net/get.php?id=2060&view=1
http://upload.overclock3d.net/get.php?id=2059&view=1
Just a small little setup. Getting average temps, comparable to my old system.
@ 3.5GHz 1.48v Real I'm getting around 60/60*C WCG, and the paste hasn't settled yet.
I've been meaning to post some pics of my beauty. :D
http://i176.photobucket.com/albums/w...9/DSC01577.jpg
http://i176.photobucket.com/albums/w...9/DSC01575.jpg
http://i176.photobucket.com/albums/w...9/DSC01572.jpg
Garu,
You better put a rubber grommet in that hole where your tubing exit/enters your case to protect the tubing, the edges of the hole might be sharp.
Those 2 blue fans in the front of your case that are blowing at your harddisks,
what size and make are they?
Those look perfect for cooling RAM.
Originally Posted by Atrin
?? :confused:
I can't seem to find good pair grommets, I tired local hardware stores... Which ones do you suggest? As you can see, I'm using 1/2" ID Tygon tubing.Quote:
Originally Posted by Zeus
Those 2 blue fans are actually blowing towards the motherboard. My mb temp used to be 45C idle. With those blowing it dropped to 34C idle. :eek:
Those are some no name brand fan I picked it from Ebay along with case mods from the guy called Thermalmaster. I'm not sure he still carries them.
Garu I love your project man :)
Tygon and UV green dye... I've had that, you don't want to know what your tubing looks like after let's say, 5 months or so :eek:
Nice build though :thumbsup:
I'm actually using HydraX. Cheap pretty good performance.
Sorry double posts.
funny, I've had tygon and HydrX for exactly 5 months now, tubing looks new and fresh, what is it supposed to look like?:confused:Quote:
Originally Posted by Garrett
I don't understand why everyone is having problems with HydrX:eek:
Nooc, what sort of temp are you getting with your setup?Quote:
Originally Posted by Nooc
40C idle and always just above 50C after an hour of Company of Heroes. Vcore is at 1.425 I believe. GPU is 52 idle/63C after an hour as well.
ohhhh....I think I've just came:clap:
