Jonny, MonsterDK... I use Windows 7 RC 64bit and have had zero issues with ET6. When you double-click it wait 10 seconds, then check your systray as that's where it will be hiding. :)
Hi,
So so,
Just trying to improve on a 1.35 VCore tried 1.325 and I got a reset. :(
Not sure what the UNCORE does but I've put that back to 3200 and I'm trying that with a 1.325 VCore to see what happens.
I was using a 3400 UNCORE with a 1.35 VCore with no problems priming after 2 hours and small 10k FFTs.
Hi
Is this memory Ok to run with the extreme?
OCZ Blade Series 6GB (3x2GB) DDR3 PC3-16000 Triple Channel (OCZ3B2000C9LV6GK)
Yes I found the more UNCORE needed more vCore, just use 16x uncore if your memory is set to 8x
Also you can try QPI/VTT 1.355v
Use LinX to test stability, it will fail fast if your overclock is not stable, 25 passes with max mem available better than waiting hours and hours priming
Can someone help me on my OC im using bios F7c and i got it up to 3800 i have a C0 920, i would appreciate some help thank you.
Try this site: http://forums.tweaktown.com/f69/ga-e...locking-31636/
Lsdmeasap does a good job explaining what to disable/enable and set when overclocking.
Still, ET6 Resets Turbo Multiplier. Makes this Program totally useless Im afraid. To bad, couse the program got it all that you need.
When using Linx to test the system for stability.
What configuration within Linx will be best to ensure its stability?
At the moment I've selected Problem size: 23118 and Memory size: 4096 MiB
EDIT:
I get LinX 64 .exe stopped working... no system reboot though.
Will linX cause the system to fall over fully if the OC is unstable?
a Tip: Why you don't try 191x20 [with Turbo enabled] so you get 21x multi [191x21= 4GHz], I'm using this settings [191x21] and it is much easy to get it stable than [200x20]
I built the MultiBoost program into the latest version of RealTemp. Just add this to your RealTemp.INI file to keep your multiplier at its max:
MultiBoost=1
http://www.fileden.com/files/2008/3/...mpBeta_330.zip
It works good for the DFI boards with 12X multi issues.
Thanks for the tips.:up: Will try them.
Oh..I miss that. Thanks.
Use this thing so people have some idea of your setting and rig.
PHP Code:Advanced CPU Features:
CPU Clock Ratio ................................ [ x]
Intel(R) Turbo Boost Tech ...................... [Enabled]
CPU Cores Enabled .............................. [All]
CPU Multi Threading .............................[Enabled]
CPU Enhanced Halt (C1E) ........................ [DISABLED]
C3/C6/C7 State Support ......................... [DISABLED]
CPU Thermal Monitor ............................ [DISABLED]
CPU EIST Function .............................. [Enabled]
Virtualization Technology ...................... [DISABLED]
Bi-Directional PROCHOT ......................... [DISABLED]
Uncore & QPI Features:
QPI Link Speed .............................. AUTO
Uncore Frequency ............................( x)
Isonchronous Frequency ......................[Enabled]
Standard Clock Control:
Base Clock (BCLK) Control .......................... [Enabled]
BCLK Frequency (MHz) ................................[ ]
PCI Express Frequency (MHz) ........................ [Auto]
C.I.A.2........................................... .. [Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[800mV]
PCI Express Clock Drive ................... [900mV]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
Advanced DRAM Features:
Performance Enhance ...................... [TURBO]
Extreme Memory Profile (X.M.P) ........... [Disabled]
System Memory Multiplier (SPD) ........... [AUTO]
DRAM Timing Selectable (SPD) ............. [QUICK]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................
tRCD ..................................
tRP ...................................
tRAS ..................................
CR.....................................
Advanced Voltage Control:
CPU
Load Line Calibration ................. [ENABLED]
CPU Vcore ..............................[ ]
QPI/VTT Voltage 1.150v .................[ ]
CPU PLL 1.800v .........................[Auto]
MCH/ICH
PCIE 1.500v ...........................AUTO
QPI PLL 1.100v ........................AUTO
IOH Core 1.100v ....................... 1.1v
ICH I/O 1.500v ........................AUTO
ICH Core 1.1v .........................AUTO
DRAM
DRAM Voltage 1.500v ..............[ ]
DRAM Termination 0.750v.......... [AUTO]
Ch-A Data VRef. 0.750v ...........[AUTO]
Ch-B Data VRef. 0.750v ...........[AUTO]
Ch-C Data VRef. 0.750v ...........[AUTO]
Ch-A Address VRef. 0.750v ........[AUTO]
Ch-B Address VRef. 0.750v ........[AUTO]
Ch-C Address VRef. 0.750v ........[AUTO]
Here are settings.
Please give advice on any changes. Thanks!
CPU Clock Ratio ................................ [ 20x]
Uncore Frequency ............................( x16)
BCLK Frequency (MHz) ................................[200 ]
PCI Express Frequency (MHz) ........................ [101]
CPU Clock Drive ..............................[900mV]
Performance Enhance ...................... [STANDARD]
Extreme Memory Profile (X.M.P) ........... [Disabled] - DO NOT SEE THIS
DRAM Timing Selectable (SPD) ............. [MANUAL]
Channel A + B + C
CAS Latency Time ......................8
tRCD ..................................8
tRP ...................................8
tRAS ..................................24
CR.....................................1
CPU Intel Core i7 920 D0 Stepping
CPU Vcore ..............................[ 1.3250 ]
QPI/VTT Voltage 1.150v .................[ 1.335]
MCH/ICH
IOH Core 1.100v ....................... AUTO
DRAM
DRAM Voltage 1.500v ..............[ 1.640 ]
