cool cheers for the reply alexey
Hello guys, here are some modifications i did to my case lastly. I removed hard disk drive caje because it was very air obstructive, so i make a new dock system for the hdd with some elastic cord attached to the 5/4 drive bays. The hard disk is cooled by a 140mm Evercool Red Scorpion Fan (a very quiet one)
Now the 120mm fan al the front intakes cool air directly to my VGA (8800GT) decreasing 3 degrees un the VGA !! So im pretty happy for it
And the hard disk drive dont move from 29 degrees !!
I hope you like it
http://img176.imageshack.us/img176/9...5resizers1.jpg
http://img262.imageshack.us/img262/2...6resizeul8.jpg
http://img519.imageshack.us/img519/5...9resizeqa1.jpg
http://img519.imageshack.us/img519/8...0resizeso6.jpg
http://img329.imageshack.us/img329/9...1resizeuk3.jpg
http://img86.imageshack.us/img86/760...4resizedd4.jpg
http://img220.imageshack.us/img220/7...5resizeqc9.jpg
http://img86.imageshack.us/img86/433...6resizeoy8.jpg
http://img228.imageshack.us/img228/8...7resizezg8.jpg
http://img90.imageshack.us/img90/808...8resizeej2.jpg
http://img214.imageshack.us/img214/5...9resizell3.jpg
http://img90.imageshack.us/img90/541...0resizeie2.jpg
http://img232.imageshack.us/img232/8...1resizetz1.jpg
http://img240.imageshack.us/img240/5...3resizend4.jpg
http://img120.imageshack.us/img120/3...4resizetz9.jpg
http://img339.imageshack.us/img339/7...5resizeel7.jpg
Aha man :D
Loving the harddrive suspending on the elastic cord :D
We need more data in the air, eh Eli? :D
C'mon guys, let's see someone w/ an 8 drive forest all swingin' away.
My loud ass raptors...i can still hear em. But they're much more tolerable than when I had em all in that damn cage of death CM provided me with.
http://img.photobucket.com/albums/v2...k/IMG_2189.jpg
Thats fantastic !! I'll do the same if i get extra hdd, i used to had a couple but a power supply unit take them out :mad:
I have to tell you that my current hdd is frozen and doesn't make any noise.
If i were you i put a raptor to the sight, to see it's show (window)
you can check here what i did to make my raptor-x silent
http://www.thelab.gr/showpost.php?p=713507&postcount=40
i used a nexus drive enclosure but I modded it a bit as it didn't had any effect on the seek noise in the beginning
now, my seagate hdds make more noise than raptor :D
I think is better refrigirated like iŽve got it !! and it looks better.
If i were you iŽll try this way and compare!
in that angle, it seems possible for me to do this my aBit IP35 PRO
http://img508.imageshack.us/img508/2...vu4cck8.th.jpg
any IP35PRO done this before?
it may conflict with your ace's 40mm fan solution.
cause its just 3pm in singapore... compared to what time it is in chicago.
Feels good to be back working with air :up: .
http://i175.photobucket.com/albums/w...DSC00820-2.jpg
Hey fella, that fan is an Evercool Red Scorpion 140mm fan (ultra quiet)
http://www.evercool.com.tw/products/...14_bview_1.jpg http://www.evercool.com.tw/products/...14_bview_2.gif
For more info: http://www.evercool.com.tw/products/rsf-14.htm
See you
This fan is very very good and quiet!
:shocked:Quote:
Originally Posted by Elian_BHZ
Next time make the pictures smaller and add them as links.
Cooljag Mini Falcon :D
3 heatpipes in a chipset cooler? I want to see reviews!
How well does that mini falcon perform? =O
