new project :D
http://img338.imageshack.us/img338/5328/img0008oc4.jpg
http://img267.imageshack.us/img267/3595/img0009nq2.jpg
http://img261.imageshack.us/img261/9173/img0010sr7.jpg
wire management is for air coolers :p:
new project :D
Neat anniversary case. Looks a bit cramped in there. Wish they made it bigger.
G thats nice, defo do some cable managment mind to really show it off. Nice short loop on the hose there. Only nig is the rad sticking up so much. Could it not be lowered or a rad box for it on the base?
thought about a rad box type mount but didn't want to drill holes in the case.
I made a 60mm offset bracket to line up the barbs with the fan hole, everything fits thru the hole without breaking the system.
Well, thats original _G_!
Really nice looking rig u got there _G_ :D
very nice pump placement. :toast:Quote:
Originally Posted by _G_
G that lian li case is wild lol i just wish you didnt have the rad sticking up like an antenna lol
I like it the way it is, but keeping the turbo shape to the case would be a must in my book if I had it. I'd put the rad in the front just for looks!
thanks guys:toast:
*looks @ avatar* :rofl:Quote:
Originally Posted by Spawne32
mounting a square rad on a round case isn't exactly easy lol
when it was air cooled it had a turbine fan hanging off the fan hole. (profile looked like a double turbo lol)Quote:
Originally Posted by safan80
http://666kb.com/i/am94mlahgmq083iw4.jpg
@_G_
The case looks nice and the rad too, but not enough space inside.. :(
How will you prime the system?Quote:
No there is no reservoir or T-line as far as I can see :)
/Thomas
Maybe filled through the top of the rad?
correct :)Quote:
Originally Posted by Xavior
I used this Syringe thru the bleed port. (if you leave the rubber washer there it makes a good seal with the tip of the syringe)
Hi,
Here are some pics of my first WC setup:D Hope you like them. :)
http://img508.imageshack.us/img508/1...alcleandh9.jpg
http://img413.imageshack.us/img413/5...oncloselc3.jpg
http://img508.imageshack.us/img508/5940/radgrillcq4.jpg
http://img413.imageshack.us/img413/3...anbovenlo7.jpg
http://img150.imageshack.us/img150/8...ingfrogti8.jpg
http://img151.imagevenue.com/loc169/..._122_169lo.JPGhttp://img41.imagevenue.com/loc18/th...s_122_18lo.JPGhttp://img159.imagevenue.com/loc247/..._122_247lo.JPGhttp://img162.imagevenue.com/loc5/th...ee_122_5lo.JPG
http://img25.imagevenue.com/loc194/t..._122_194lo.JPGhttp://img102.imagevenue.com/loc107/..._122_107lo.JPGhttp://img14.imagevenue.com/loc55/th...m_122_55lo.JPG
Sad news is my X1900XTX didn't survive the installation:(
any ideas ? :confused:Quote:
Originally Posted by Atrin
Ofcourse Bro:cool:Quote:
Apogee Gt Extreme:cool:
Nicely done there dude. Must of been an ass to ffill taken some time but very rewading as the same time. Leats the DDC wouldn't of ran dry, lot of water in them PA's
This is one i did for the "lads magazine" Maxit
The only criteria was it had to be yellow and black with all components supplied by Maxit themselves which consisted of the following and all parts were cut free hand with a fret saw...
Yellow Wavemaster
Asus P5B Deluxe
Conroe 2.4GHz
2x Mushkin XP2-8000
XFX Geforce 7900GT
Be Quiet BQT ES-700W PSU
http://www.coolercases.co.uk/maxit/dans-sig.jpg
http://www.coolercases.co.uk/maxit/69c.jpg
http://www.coolercases.co.uk/maxit/50c.jpg
http://www.coolercases.co.uk/maxit/99_c.jpg
http://www.coolercases.co.uk/maxit/101_c.jpg
http://www.coolercases.co.uk/maxit/103_c.jpg
http://www.coolercases.co.uk/maxit/105_c.jpg
Amazing case man. Clear inside and great pain job :wave:
Nice case... Im just afraid that the rad grill is restricting airflow/creating noise due to turbulence in the air.
I like the theme though... yellow and black.
@coolmiester, how did you manage to get the coolant to such nice uv green ? thanks
Yeah I'd like to know too:stick:Quote:
Originally Posted by XProfessionalX
Check his webiste out, has a stikcky in there forum about there UV dyes
