Newer build of 8.79.6!
RC2 Dated December 7
HD6970
http://3dmark.com/3dm11/150976
HD5870
http://3dmark.com/3dm11/137734
http://i55.tinypic.com/1zdq8eq.jpg
HD6970
HD5870
Does anyone has a link to GPU-z 0.5.0?
Remember, this Ducati750ss boy is benching with PowerTuner ON (0%). It means GPU clock is floating around 700~880MHz to always stay under default power. Tell him to change power limit via CCC Overdrive to maintain clock straight @880MHz and Cayman will show you what it's capable of.
And what about the slider?
It seems they also fall with that 6718/6719 confusing data info. The one that supposedly comes with the "cat10.12" and exchanges 6718 for 6950 instead of 6970.
Remember the "class of it's own" thing? If real and the 6950 performs equal or slower than 5870(since 6970 is only a bit faster) that doesn't make any sense.
In german forum someone asked him this "google translation"
And Ducats response.Quote:
Posted by Kudd3l
To the owners of the HD6970, did you really once dealt with the new Powertune function?
When the HD6950 as it is so that the typical gaming power of 140W is set to Powertune, PowerTune maximum power lies with 200W.
Meaning, it is quite possible that it the HD6970 with the handbrake on and thus not bencht with the maximum possible performance.
Would be nice if you could make a few screenshots of the Powertune function where you can see the settings, if that's even possible at all in the driver version.
So according to Ducat card doesn't throttle on core clocks , its quite possible none of the games force the card to throttle and performance is what it is.Quote:
Posted by Ducati750ss
Sounds even logical, but as I said, the card runs at 880MHz while the benches and 99% load. Und wenn man sich meine Verbrauchswerte anguckt, muss die auf voller Leistung laufen. And when you see Staring at my fuel consumption must be running on full power. Because PowerTune harry97 can only watch the same times. In my old CCC I've seen nothing like this, watch when harry on it pulls like the new one.
Well, according to this Vantage test I can see a low FPS in Perlin Noise due to clk drop
So basically you're getting an 470 and 480 in AMD flavor with less heat and power consumption. Isn't that what everybody wanted? :)
Oh wait nvidia just launched the 570 and the 580. I have to say the 570 is and will be a phenomenal deal.
meh this benchs mean nothing without cayman special drivers
