I am glad I still have my UD7:ROTF:
in the bios if you enable the Extreme OV, it appears more options
QPI Voltage OCP
OCP Voltage IOH
DRAM Voltage OCP
QPI PWM Frequency
IOH PWM Frequency
DRAM PWM Frequency
is that with OC h24 is better to enable this option or not?
thank you ;)
I got lucky with the tim. I only had one tiny patch on the IOH and thats it. I just scraped it off with a piece of plastic, took me 10sec. I really dislike the EK standoffs, they use them for everything. It makes it so much more difficult lining them up and getting them to stay there while you put the block in place. I which they would just machine them as part of the block itself. They really like their standoffs. My temps are an average of 25C lower now.The block looks great too. I will take some photos and post them soon.
I dont mind the stand-offs as they can be made to fit perfectly if you have the time to sand them down if needed. If they are built onto the block and they are wrong = buggered.
I find using a tiny (and I mean tiny) blob of AS5 gets the stand-offs to stay perfectly in pace. You really need to screw up before they are in the wrong spot.
my temps on the stock tim are like high 30's low 40's
i heard of ppl with it was in 90's on first boot, thats crazy but seen most are hotter then mine here :D
Is this with Gulftown? If so, that's two reports of Gulftown not having this issue.
Doesn't help me though :(
What I need is for my Gigabyte board to come back from RMA so I can verify again that it is not the processor.
I've had this issue with all 4 chips I've tested with on the RIIIE (920, W3520, two 950's).
I have a ten minute video of me trying to boot at 224 BCLK. It took around 3 minutes to boot. I switched the BCLK down to 220 and it took the usual ~30 seconds. Once it boots I try to run Vantage. It's kinda funny to see that at ~1-20 fps.
I'll upload it when I publish my stuff this weekend.
today i got Beta Bios 1102 for Rampage 3 Extreme
The bios is dated on 23.09.2010
The Bios fixes following
1.Patch CPU temperature may display 0 degree issue
2.Updated CPU micro code(s) for Gulftown i7-980X B-1 CPU
i will flash the bios tonight and report back
regards
i sold my 920 like 2 weeks before i got this R3E, but i could only get it to run 225X21 was the highest for 3D then i needed to use slowmode, i might try the other MB its a P6X58D Premium i never tryed to see the max bclk on the 980 on it
how high do you go on your pci-e mhz ?
What's the highest BCLK achieved without SM enabled?
Mine has started doing something similar. I hit shut down it shuts down windows. Screen goes blank, then it just sits there for eternity. Although I can still hit the reset button to get it to reboot.
First Asus board I've bought in 4 years, already had to RMA it once. Not looking forward to RMA'ing a month old board again.
i flashed bios 1102
the bootblock is grown from 43 to 45
after flash to 1102 my gulftown stuck at 3333mhz
after cleacmos all is fine
http://www.abload.de/img/zwischenablage010l9j.jpg
test now (NO oc)
BBB=Bios Boot Block
Hi Everyone,
I just got the board and i7 950, just wonder do I have to use 2x8 pin EATX12V for the board? What if I just use 1? Any stable problem with that? Many thanks for your help :)
You only have to use one. I have this board with a i7-950 running on a Corsair TX 750w. Currently running the CPU at 3.8GHz (166 bclk) with all stock voltages and temps never exceeding 55c on everyday use stuff. Im positive I could hit 4GHz with a small increase to voltage.
