Noted for future use. I have fans, pumps, and an NZXT Sentry fan controller yet to sleeve.
That's a real nice one Unrealer..
nice work sir sqw33d and anthony8659..pinoy power!
http://www.zimagez.com/miniature/up111.jpg
http://www.zimagez.com/miniature/dscn27751.jpg
http://www.zimagez.com/miniature/up210.jpg
Quick build in 3 days :D
Q9550@4020mhz/ Ybris Eclipse
GTX280@770mhz/ EK FC-280GTX
MCP655, BP fittings, Magicool 280 qith 2 noiseblocker PK2
Really good cooling for only one 280 radiator, 53°c in full at 1.37v :D
Lovin the rigs in here. I will update mine soon :)
some niiiiiice builds in this thread. wow!
EK Supreme HF Full Nickel
EK FC5850 Nickel + Acetal
GTX360 w/ San Ace H101s
MCP355 w/ XSPC restop
BP Black Sparkle compressions 7/16 x 5/8
http://img810.imageshack.us/img810/1831/dscn0599.jpg
http://img830.imageshack.us/img830/4775/42497119.jpg
http://img121.imageshack.us/img121/985/dscn0591jx.jpg
And this was with my AM3 setup
http://img823.imageshack.us/img823/4233/dscn0112dg.jpg
Ughhh, I have a lot to learn.
Beautiful builds!!!
So your actually going bottom up from GPU to CPU and then the rad?
Was that to keep things clean or for any other reason?
mmm haven't seen a rage posted in a while. Can't wait to get my haf back from the coaters so I can start putting the wc goodness together and finally post.
Considering your running the same board and relatively the same cpu with the same pump and res top as I will although I will have a little extra above that res top, but that's irrelevant. What are you running the cpu at and what are the temps? I'm curious since I will be doing the same thing running that pump and top for the NB and cpu. Have a separate loop for my 5870 though. Granted my loop will probably cool a few degrees more since I'm running a 480 for the cpu/nb loop.
Yup pump --> gpu --> cpu --> nb --> rad --> res
Just make it look way cleaner.
4.0 @ 1.3v (1.33v load) on the i7. Board won't let me go below default which is 1.3v. My 5850 is at 975/1200 @ 1.2v.
60-65c load on the CPU and 37c load on the GPU. Both go up about 2-3c when they are both under load.
Less talk, more builds. :hammer:
Finally after months of slaving away over hot GPU's I can has cheezburger !!
http://a.imageshack.us/img31/4516/img0270os.jpg
http://a.imageshack.us/img830/1159/img0269sq.jpg
http://a.imageshack.us/img704/3730/img0272r.jpg
http://a.imageshack.us/img838/6983/img0271me.jpg
My first attempt at WC ... now I either never ever ever do it again ... OR ... I become addicted :p
decisions !
OCD-OC
very nice loop :up: good job mate
OCD-OC
