my current settings, Uncore 17x / memory 8x / vcore 1.23v / qpi/vtt 1.335 / memory 1.62v / HT ON / turbo boost disabled .... all other settings set to auto:
http://i41.tinypic.com/2a9blv8.jpg
coretemp 75/75/70/70, any comments?
is that a normal behavior? only happen after shutdown and power on
when I power on my PC, I could hear like 3 resets happen (the blue led behind the ram which show your OC level turn off and on like 3 times) it doesn't shutdown and power on again, it just doing like 3 reset in the row without any shutdown, I entered the bios after, but it doesn't say anything about reverting from bad OC, and every stress test passed fine.
Can someone help me on my OC im using bios F7c and i got it up to 3800 i have a C0 920, i would appreciate some help thank you.
I'm not sure what you mean by this exactly.
But this is what I looked at (??) Easy Tune 6 Clicked Advanced under the Tuner option, then Voltage 1.
Then looked up QPI/Vtt Voltage. Under 'Power On' it shows 1.53500V
Is this the value I was looking for or am I way out?
That's too much, try to manually set it to 1.335v or 1.355v
here is my settings for 3.82GHz
http://www.xtremesystems.org/FORUMS/...postcount=2876
"Target" are the Values currently used
Anybody?
Ive started again working up the BLCK with the below
Multi.................... 14
Turbo .................... Disabled
Speed.................... 2800
CPU Multi Threading.................... Enabled
CPU Enhanced Halt (C1E).................... Enabled
C3/C6/C7 State Support.................... Disabled
CPU Thermal Monitor.................... Enabled
CPU EIST Function.................... Enabled
Virtualization Technology.................... Enabled
Bi-Directional PROCHOT.................... Enabled
QPI Link Speed*.................... 36
QPI Link Speed (MHz).................... 7200
Uncore Frequency.................... 17
Uncore Frequency (Mhz).................... 3400
Isochronous Support.................... Enabled
Base Clock (BCLK) Control.................... Enabled
BCLK Frequency (Mhz).................... 200
PCI Express Frequency (Mhz).................... 100
C.I.A.2.................... Disabled
CPU Clock Drive (mV).................... 800
PCI Express Clock Drive (mV).................... 900
CPU Clock Skew (ps).................... 0
IOH Clock Skew (ps).................... 0
Performance Enhance.................... Turbo
Extreme Memory Profile (X.M.P.).................... Profile1
System Memory Multiplier (SPD).................... 8
Memory Frequency (Mhz).................... 1600
DRAM Timing Selectable (sPD).................... Quick
CL.................... 8
tRCD.................... 8
tRP.................... 8
tRAS.................... 24
CMD.................... 1
Round Trip Latency.................... Auto
tRC.................... 41
tRFC.................... 88
tRRD.................... 6
tWR.................... 12
tWTR.................... 6
tRTP.................... 6
LoadLine Calibration.................... Disabled
CPU Vcore.................... 1.26875
With vdroop.................... 1.2
QPI/VTT Voltage.................... 1.315
CPU PLL.................... 1.8
PCIE.................... 1.5
QPI PLL.................... 1.1
IOH Core.................... 1.1
ICH I/O.................... 1.5
ICH Core.................... 1.1
DRAM Voltage.................... 1.64
But when raise the multi to the dizzy heights of 15 (3GHz) it will just lock up, ive tried uping each voltage one by one but it still lock in the first 17s of LinX.
Your UNCORE frequency should be double your RAM speed (3200 whereas your is 3400), this might be a problem !?
any chance of speeding up the boot up time on jmicron raid for the ex58 extreme? i was able to borrow my old msi eclipse and did try to setup the HW raid on both eclipse and extreme and i clocked that the eclipse is around 3-5 secs faster than the extreme :( Also I attached the silent pipe and my IOH cooling is pretty good but i am not happy with the build in sound of the giga board so i am planning to buy xfi platinum pcie. I can put that in the last x16 slot ( configure as x8 ) right ? or is there another driver aside from realtek ( of there are any 3rd party driver that works with vista 64 please ) that can improve the sound quality of this board ( well to save some cost on my part ).
my setup
ex58 extreme - f8b
i7 920 cooled by hr01+
g skill 3 x 2 gig ddr3 1600 8-8-8-21 1.6v
MSI gtx275
2 x 74gb WD raptor 10k rpm 16mb cache -- raid 0 via HW raid
1 tb + 640 gb WD black for data and games :)
700W PSU
Prime95 'ing the rig and getting lock ups and reboots after about 10 mins of Torture testing....
Hardware
UD5
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Socket LGA1366)
OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- 1.65 Volts
Water Cooled on a Quad Rad (temps don't go above 60)
CPU Clock: 20 x
Uncore: x 16 (3200) (tried 3400)
BLCK: 200
RAM:
8
8
8
24
1
Load Line: Enabled
CPU VCore: 1.3V
QPI/Vtt: 1.335V (also tried AUTO)
Dram Volt: 1.64V
Any suggestions please?
anyone know what "Round Trip Latency" exactly do?
mine are Auto set to /55/57/60
Can I tweak them?
guys, running a D0 @ 4GHz with 1.28v is considered good?
Updated version:
EasyTune 6 B09.0421.1
boldenc,Lower is better, and you may freely tweak it.Quote:
Originally Posted by tweakers.fr
Is it just me or is ET6 a no-no on Windows 7!?
It installs ok, and the GUI process is running but I see nothing after clicking.
Tried a variety of compatability options and still nothing.......HELP!!
