Originally Posted by
unclewebb
JohnZS: I always like seeing your numbers because it helps demonstrate some of my crazy theories. Between the 30% and 88% level, core2 goes from 65.9 to 49.8 which is a difference of 16.1 and core3 goes from 60.6 to 44.3 which is a difference of 16.3. The slope error difference is only 0.2 degrees. The rest of the difference is all a difference in TJMax between two cores on the same die. How's that for quality control?
Your data suggests different TJMax values for each one of your cores. Some cores are pretty close, core0 vs core1, while others like core1 vs core2 might have a TJMax difference of 10C or 11C. :eek:
You don't read about stuff like that in the publicly available Intel docs but the numbers in the Cool Down Test tell a story that is hard to argue against. I still plan to have a good look at your numbers and come up with a calibration suggestion for you so bug me on a regular basis. I should have time in the next couple of weeks.
