I expect my toys to do work!
I hear you bro send it in and get a replacement I am suprised you did not do that months ago when you had the Raid or sata issue with the raptors.
I got my present mobo just before Christmas. Apart from testing for the best strap, ram speed and of course clock, it has been running Orthos 24/7. Since getting an 8800 Ultra it has been benching, Orthosing and generally hammered 24/7. No Bsods, unprovoked restarts, nothing, it just runs. That is at 4.24ghz and under phase. My NF4 Ultra-D ran in the same way as well. Once you master a DFI and understand the relationship between all the ram settings, there just is'nt a faster or more stable mobo out there.
Me too, the DFI LP UT P35-T2R is a killer, solid, fast, super tweakable board & easily the best board I have had since my DFI NF4 Expert.Quote:
Originally Posted by MikeMK
Yep, no probs with mine either... rock stable. Best board Ive had in a long while... and ive been through a few!
Everything I have put in contact with my P35-T2R is & has been maxed out with zero trade offs I simply cant ask for more!!!
The funny thing is my Asus P5K DLX was all be it screaming fast the worst board I have had in a long time & as it happened it wouldn't run for more than 2-3 days 24-7 before rebooting.
CN :)
has anyone tried the beta bios 12/27?
new settings? performance increase?
tnx :)
Thanks for the heads up on this. Downloading now and will flash later today after this prime session is complete. This bios has totally replaced the 12/24 as that is no longer even listed as a download where as all previous beta bios are still listed for download. The reason of change may help those who are having issues clocking the new 45nm CPU's on this board??
Major Reasons of Change:
Added 45nm CPU VTT Voltage control table.
I will try the new bios, i hope i can start my qx9650 with this.
Tried the 12/27 beta bios, but its buggy and dont resolve my issues with qx9650 . From yesterday i cant manage to run qx9650 with this board :(:down: .
http://mekk.homeip.net/imagesharing/...5ff44a21a7.jpg
http://mekk.homeip.net/imagesharing/...6a17d540d4.jpg
I also am on a qx 9650, on the first official with penryn support. 11-07 and so far all seems well, I do get the 88 code (but it does recover )if I try to set 11 multi though but 10 seems fine for now, just happy to have it running.
my x-38 didn't recover from 88 codes without a cpu swap .(and i use phase cooling, so that is a pain). after catching up in this thread I tried my p-35 and so far so good.
12/05 beta bios gave me highest stable FSB I've had on yorkfield so far (480), no error codes:
http://i90.photobucket.com/albums/k2...s47a/8x480.jpg
12/24 is here http://us.dfi.com.tw/Upload/BIOS/LP35DC24.ZIP it was upgraded to final/retail rather than staying BETA.
I put my spare chip in last night & swapped back from my E6850 to my Q6600 & it run prime blend all night @ 3.8GHz DDR 1190 its a good BIOS IMO.
CN :)
Yea I went back and noticed it was now made official as well.
C-N that is one sweet overclock you got there. My gosh, 3.8ghz on a Quad core and 1190 on the ram. That system is something to be proud of. Here I am excited that I hit 3.4ghz on my Q6600 and then you come along...
I believe you can do better if that's a slacr Q6600, 3.4GHz on TRUE is somewhat average..
I finally got round to having a proper play with the 1224 BIOS & for me its a good one.
I find 1224 to be a tad slower clock for clock compared to my old favourite 1019 BETA BIOS which IMO is down to the memory being backed off a touch but apart from that its killer & its an official non BETA BIOS.
The BIOS template is attached if anyone can make use of it be my guest.
Here's my specs & settings for anyone thats interested.
DFI LANPARTY UT P35-T2R (BIOS 1224)
INTEL CORE 2 DUO QUAD Q6600 KENTSFIELD 2.4GHZ 4M L2 CACHE (L19B)
OCZ PC2-8500 SLI 2 x 1GB PN:OCZN1066SR2GK
INNO3D 8800GTS 320MB (163.75 DRIVERS OVERCLOCK 617 X 955)
4 X HITACHI DJ 80GB HD'S (RAID 0 / 64K STRIPE)
SONY DUAL LAYER DVD RW (DRU-820A)
OCZ GAMEXTREAM 1010W PSU
WINDOWS XP PRO SP2
CPU COOLING: D-TEK FUSION + PA130.3 + D5 VARIO
PRIME95 + 3DMARK2001SE + 3x CPU-Z:(SCORE 64130)Code:>CPU Feature:
Thermal Management Control.......... - Enabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Enabled
Virtualization Technology........... - Enabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Auto
>Clock Setting Fine Delay Press Enter:
Ch1 Clock Crossing Setting......... - More Aggressive
DIMM1 Clock Fine Delay............. - Current[1486ps]
DIMM2 Clock Fine Delay............. - Current[612ps]
Ch1 ControlFine Delay.............. - Current[1012ps]
Ch1 ControlFine Delay.............. - Current[562ps]
Ch2 Clock Crossing Setting......... - More Aggressive
DIMM3 Clock Fine Delay............. - Current[1337ps]
DIMM4 Clock Fine Delay............. - Current[524ps]
Ch2 ControlFine Delay.............. - Current[1086ps]
Ch2 ControlFine Delay.............. - Current[449ps]
Ch1 Ch2 Common Clock Setting....... - More Aggressive
Ch1 RDCAS GNT-Chip Delay........... - Auto
Ch1 WRCAS GNT-Chip Delay........... - Auto
Ch1 Command To CS Delay............ - Auto
Ch2 RDCAS GNT-Chip Delay........... - Auto
Ch2 WRCAS GNT-Chip Delay........... - Auto
Ch2 Command To CS Delay............ - Auto
CAS Latency Time (tCL).............. - 5
RAS# to CAS# Delay (tRCD)........... - 5
RAS# Precharge (tRP)................ - 5
Precharge Delay (tRAS).............. - 10
All Precharge to Act................ - 5
REF to ACT Delay (tRFC)............. - 26
Performance Level................... - 6
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In.......... - Auto
Channel 1 Phase 1 Pull-In.......... - Auto
Channel 1 Phase 2 Pull-In.......... - Auto
Channel 1 Phase 3 Pull-In.......... - Auto
Channel 1 Phase 4 Pull-In.......... - Auto
Channel 2 Phase 0 Pull-In.......... - Auto
Channel 2 Phase 1 Pull-In.......... - Auto
Channel 2 Phase 2 Pull-In.......... - Auto
Channel 2 Phase 3 Pull-In.......... - Auto
Channel 2 Phase 4 Pull-In.......... - Auto
MCH ODT Latency..................... - Auto
Write to PRE Delay (tWR)............ - 11
Rank Write to Read (tWTR)........... - 10
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - 8
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
Read CAS# Precharge (tRTP).......... - 3
ALL PRE to Refresh.................. - 4
>Voltage Settings:
CPU VID Control..................... - 1.55000v
CPU VID Special Add................. - Auto
DRAM Voltage Control................ - 2.27v
SB 1.05V Voltage.................... - 1.150v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.65v
CPU VTT Voltage..................... - 1.60v
Vcore Droop Control................. - Disabled
Clockgen Voltage Control............ - 3.60v
GTL+ Buffers Strength............... - Weak
Host Slew Rate...................... - Weak
GTL REF Voltage Control............. - Disable
CPU GTL1/3 REF Volt................. - 115
CPU GTL 0/2 REF Volt................ - 115
North Bridge GTL REF Volt........... - 115
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
Exist Shutdown After AC loss........ - Disabled
O.C Clock Fail Retry Counter........ - 0
CLOCK VC0 divider................... - Auto
CPU Clock Ratio Unlock.............. - Enabled
CPU Clock Ratio..................... - 8
Target CPU Clock.................... - 3840MHz
CPU Clock........................... - 480
Boot Up Clock....................... - 350
DRAM Speed.......................... - 266/667
Target DRAM Speed................... - 1203MHz
PCIE Clock.......................... - 100mhz
PCIE Slot Config.................... - 1X 1X
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
SATA Spread Spectrum................ - Disabled
http://i106.photobucket.com/albums/m...8/3DMARK01.jpg
3DMARK2003:(SCORE 38221)
http://i106.photobucket.com/albums/m...8/3DMARK03.jpg
3DMARK2005:(SCORE 20084)
http://i106.photobucket.com/albums/m...8/3DMARK05.jpg
3DMARK2006:(SCORE 12300)
http://i106.photobucket.com/albums/m...8/3DMARK06.jpg
AQUAMARK 3:(SCORE 211,726)
http://i106.photobucket.com/albums/m...8/Aquamark.jpg
SHORT DESCRIPTION:
480 x 8 = 3840MHz @ 1.550v
5-5-5-10 2T @ 2.270V DDR 1203
Hey, anyone know if the 45nm wolfdales clock well on this board?
@C-N: Nice one C-N..thanks for the info! :up: i'm playing around with the 12/24 too. though you'd be strapping on the E6850. by the way, is it safe to keep than vDIMM @2.27v, NB Core @1.65v
CPU VTT @1.60v?
Thanks & your welcome.
TBH I sold off all my spare CPU's ready to get a 9650 but the money burnt a whole in my pocket, I figured I would get the E6850 to go with my P35-T2R so I could replace my old 875P-T file server when I got hold of an X38 board.
I am not so sure I will bother with x38 now as all I see is problems rather than advantages maybe I will wait for X48 :shrug: maybe x48 will be better :shrug:
I have had a quick play with the E6850 & I am real impressed with it, she runs nice @ 4GHz 1.475v DDR1250 2.31v on the 266 strap & it can bench some real nice numbers too.
CN :)
I only ran the E6850 overclocked for a couple of days so I don't really have any proper long term tested 24/7 settings. I did run it for 2 days @ 4GHz DDR 1200 after getting it 9 hours Orthos stable, my settings & screen shot are below same hardware just swapped Q6600 to E6850.
I didn't make any screen shots @ DDR 1250 but it was basically just the next strap/divider up tcl:5, trcd:5, trp:5, tras:10, all precharge to act: 5, trfc:26, read delay 6 vdimm:2.31v, vnb 1.65v & everything else the same as DDR 1200.
I will probably sell the E6850 fairly soon & get a 8400/8500 & a 9*50 I just cant help myself :D
http://i106.photobucket.com/albums/m...0/3DMARK01.jpgCode:>CPU Feature:
Thermal Management Control.......... - Disabled
>DRAM Timing:
DIMM1 Clock Fine Delay............. - Current[0]
DIMM2 Clock Fine Delay............. - Current[5]
Ch1 ControlFine Delay.............. - Current[8]
Ch1 ControlFine Delay.............. - Current[6]
DIMM3 Clock Fine Delay............. - Current[0]
DIMM4 Clock Fine Delay............. - Current[6]
Ch2 ControlFine Delay.............. - Current[8]
Ch2 ControlFine Delay.............. - Current[5]
RAS# Precharge (tRP)................ - 4
All Precharge to Act................ - 4
REF to ACT Delay (tRFC)............. - 30
Performance Level................... - 7
>Voltage Settings:
CPU VID Control..................... - 1.47500v
SB Core/CPU PLL Voltage............. - 1.75v
NB Core Voltage..................... - 1.45v
CPU VTT Voltage..................... - 1.35v
GTL+ Buffers Strength............... - Strong
CPU GTL1/3 REF Volt................. - 93
CPU GTL 0/2 REF Volt................ - 93
North Bridge GTL REF Volt........... - 93
Target CPU Clock.................... - 4000MHz
CPU Clock........................... - 500
DRAM Speed.......................... - 333/800
Target DRAM Speed................... - 1201MHz
Thanks so much C-N! Really really appreciate the effort. :)
are the only differences between the UT and LT version the heatpipes?
