I haven't heard a similar prob for a long time on a P5B also...Quote:
Man if this actually turns out to be the issue I'm going to be so happy yet so freaking pissed that it was this and didn't have to buy a new board to begin with LOL... I mean usually if something burns out like an nbridge chip or cpu or something you can smell it... and the simple fact that my pc was working fine until a reboot one day should pretty much mean it's not an actual hardware incompatibility issue... Where can I find that list of compatible RAM at for this board?
I'd be willing to bet that our mobo's have pre-07xx bios.Quote:
Yeah my mboard came with like revision .5xx lol
QVL RAM is on the left side of the product page...Actually since it only goes up to DDR2 6400 RAM there isn't anything on there that needs more than 1.8v I think. It hasn't been updated either since I looked at it last August.
http://usa.asus.com/100/download/pro...79/1179_10.pdf
well it happens to me 3 times already....unplug de 24 pins and the 8 pins from the cpu,took off the batterie,one dimm on the yellow slot further from the cpu,and clear cmos all night long.Quote:
Originally Posted by mrt2
Well trying the only one stick of ram seemed to have done the trick for me! =)
Thanks for all your help guys.
In bios under the hard drive options where it says how to run the sata drives... the options are RAID, IDE and ICH8.... what does ICH8 do? Anyone know?
ICH8 is AHCI mode, update your BIOS, since 0711 it doesn't say ICH8 anymore, it says AHCI as it should.
i have overclocked my e6400 to 3.2 Ghz but at post it reports my clock speed to be 16.92GHz !!!!!!!
wtf
windows & cpuz reports the correct speed
anyone else have this ???
So what is AHCI mode?
that's normal, don't worry about it. it's just stupid incorrect readouts.Quote:
Originally Posted by strad
The Advanced Host Controller Interface (AHCI) is a hardware mechanism that allows software to communicate with Serial ATA devices such as host bus adapters which are designed to offer features not offered by Parallel ATA controllers besides higher speeds, like hot-plugging and native command queuing (NCQ). The specification details a system memory structure for computer hardware vendors, in order to transfer data between system memory and the device.Quote:
The AHCI protocol was announced by Intel in a May 2003 press release.
(Excerpt from Wikipedia)
http://www.google.com/search?num=100...afe=off&q=AHCIQuote:
is this XtremelyLazy.org/forums ? ;)
Yeah thats why we build computers that can think for us :DQuote:
Originally Posted by Alexandrus
Ok maybe I asked the question wrong then... I didn't really need to know WHAT it was... in my head when I typed that I was actually thinking... what are the performance advantages over setting it to IDE in BIOS... Like real world performance... will I actually notice a difference in load times etc...?
If u do mutitasking - yes, if u do normal operation - slighty or none.
That is offcourse in theory, u cant know until u make the comparison realtime.
Maybe somemone that has been using IDE and reinstalled to ACHI, can share some info?
So anyway, yesterday I finally got my gpu and mem, so i assembled it, and booted. I was happy as a child, since i was w/o cmp for almost 3 months. :woot:
It booted fine, i got into BIOS and set it up and when i pressed save, I almost got a heart attack - computer shutdown like I cut power to it... I could hear my HD head fell as a rock. :slobber: :slobber: And then it turned on again by itself fine.
I have read all there is about this board, but until u acctually experiance this, u have no idea how it really feels, esspecially if u have data on disc, or after u did OC.
And then during post i saw that my revision is 0507. Jesus, its even miracle i booted fine.
I can tell u, ASUS makes good boards, but always manages to kill all that hard work and beauty with some little crappy thing that annoys hell out of ppl. :slapass:
After that I had a mishapp with partition magic, so i spent all night repairing partitions... and then i realized that i forgot my AIO in the firm, so i went to sleep, and will be finally doing the system in about an hour or so.
Piece of advice which most of u probably allready know : Never do anything with computer when u are tired. U will live longer :D
Next time i write here it will be from my own comp :banana: :banana: :woot: :banana: :toast:
if your drives do not support NCQ then i assume there is no benefit to using ACHI mode?
Can't get my CPU lower than 50C idle for some reason... I bought a new board because some other issues and added EXTRA AS5 this time on the chip but no matter what I do, it still stays between 47 to 50C at idle... what could I be doing wrong? Maybe I'm mounting it wrong or something else? There is an issue with the square piece of foam around the backplate of my cooler (Tuniq Tower)
Since it had adhesive on it and stuck to my original board....but I don't really think that piece is THAT important...I got the backplate on just fine and screwed the HSF in as tight as I could without cutting my fingers too much LOL... why in the heck do they make that heatsink so freaking sharp...? LOL
ANYHOW this has actually made me want to try other types of cooling other than air...but I'd rather stick with what I bought than spending more cash...
Suggestions?
OH YEAH this HSF is REALLY hard to get on so in installing it, it does slide around a bit...could that have slid some AS5 onto the side of the IHS possibly or something or what? Any help would be appreciated.
More AS5 can actually increase temps, maybe you should try lapping the base of the cooler and properly installing it again.
Hey guys, which bios are you using on P5B DLX, is there any modded bios which works good on that mobo?
regards
Gosh, I was using only 1gb stick ... So I decided to buy another 1gb today for dual-channel ... cpu-z show as dual channel, so does the bios at boot.
I tough about getting a higher score at PcMark05 , but no increase whatsoever for dual-channel ? WTF ?
I've made some testing with 0804 and 0910 regarding PECI option in CPU Functions.
On 0804 with PECI disabled TAT reports bad temps, one core with negative temps, and the other with positive. -43/~50.
If I enable PECI everything comes back to normal. ~48-50 in idle with TAT and ~35-38 with Asus Probe. On load with Probe goes up to 50.
On 910 with PECI enabled or disabled I get same temps with TAT(idle 50/load 65).
But with ASUS Probe, with PECI disabled the temp remains constantly at 40(idle or load).
After enabling PECI the temp with ASUS Probe is higher than the one reported with 0804 bios, being around 40. Also higher on load, 55C.
Pretty strange, I might say. Hope I haven't done anything wrong or get confused with all those temps.
My C2D is at 3.1Ghz, 1.32 idle, 1.304 load, 1.350 bios.
So what does PECI do afterall ?
LittleDevil Everyone use the last one (0910 current). There is no any modded bios, cause it inpossible to do it.
Hey, maybe disabling or enabling PECI can hlp with sub zero temps? Cause I remember when it was auto - TAT always reports that CPU temp is +13, but in real it was -17.9(S&M says that) Anyone can try?
