its my tccd on 5/6 207mhz 2.5-4-4-8
maybe not ram...lol....hows teh voltage in your PSU...rails nice and stable?
New 150 CABNE... Memory was at 1/2 in this shot. This also was on stock HSF, waiting to hear more about SLi Expert board eating CPU's before I install in the Vaporchill.....
http://www.gadtek.com/150-2-1.jpg
CABYE 0540FPBW is the best for 146 now and for the 148 also.
...I think you could be wright but...are really really hot!...I an my @3ghz 1,424V SP2004 for 8 hours and get temperatures around 47-48°C under water!...I think will remove the HS this week... :stick:Quote:
Originally Posted by Rufus7
Regards,
Primoz
Nice to see you back in action SAE :toast:Quote:
Originally Posted by SAE
heheh new personal record :) with icewater
http://img352.imageshack.us/img352/9529/jee22uu.png
:woot:
I picked up a couple in Hong Kong ...Quote:
Originally Posted by TEDY
Got mine hereQuote:
I don't know your block, but I get 29 idle - 38 Load with a Nexxos XP, at 3050 Mhz.Quote:
Originally Posted by Primoz78
still cooled by puny 1/4" tubed Corsair Hydrocool 200 in 30+ C room temps
Awesome broke 23m 10s barrier
Super Pi 32M
@3102mhz = 23m 23.735s
@3120mhz = 23m 14.547s
@3130mhz = 23m 10.297s
@3133mhz = 23m 08.500s
@3141mhz = 23m 05.891s
@3150mhz = 23m 03.531s
but higher isn't better either. i'm the owner of a CABNE 0530APMW #0001. it does 2.9ghz with 1.425v, not the best, but also definitly not bad ;)Quote:
Originally Posted by ben805
it really comes down to luck more than anythin else
We have ordered 4 of this CPU`s with same stepping...and all 4 have the same issue with temps...so the blocks are OK... :rolleyes:Quote:
Originally Posted by skogkatt
Regards,
Primoz
Primoz78: What's the room ambient temp?
146 CABYE 0540FPBW
- 2900MHz 1.408Vcore StressPrime +28h stable
Now 3006MHz 1.408V, 2x256mb Corsair BH5 273FSB 2-2-5-2-7-13 1T 3.6V, StressPrime has run now 45min., let's hunt for +24h :D
Cooling: TT BigTyphoon, ambient around 23ºC -> CPU 40-43ºC under stress
About 18-20°C...I`m wondering what will be the temperature in summer months... :confused:Quote:
Originally Posted by Monge
Regards,
Primoz
Not sure I'm getting your answer...I was wondering if your water block was good enough (or your WC system). Of course if your room temperature is around 30C that could explain your results ;)Quote:
Ok.Quote:
Did you try to measure max. T-case and thermal offset with CBI or another program - I don't remember the name?
Maybe it has to do with the core/IHS.
Edit: Here you go:
http://www.thecoolest.zerobrains.com...topic.php?t=83
http://users.skynet.be/pt1t/146/prime_3200mhz.PNG
opteron 146 CABYE 0540 FBPW #224
Watercooling
ambiant temp ~ 17°
Full ~ 47°
Thats normal for an 146Opti 0540FPBW.
Heres a link for similar clocks but Prime 95
http://monsterprozi.mo.funpic.de/opt146html.htm
yep this 146 cabyes 0540 FPBW re very good i ordered last one today for a friend mine here in portugal for 180euros , the other guys who bought the others 146 cabye 0540 fpbw in same store all of them hit 3000mhz@1.45v aircooling . :DQuote:
Originally Posted by Dani
Maxtcase is 59°C...thermal offest...don`t really know what is ths... :confused:Quote:
Regards,
Primoz
Orderd a 146 CAYE yesterday, from www.komplett.se it seems like all of komplett´s 146es are CABYE 0540 :D
I think you need CBID to read thermal offset:Quote:
http://cbid.amdclub.ru/html/download.html
Read about max. T-case and thermal offset here in this thread:
http://www.i4memory.com/showthread.p...9&page=1&pp=30
There's also a thread here on XS.
Monge :toast:
Yep, it's the same here in Norway too. Think I'll mine on Wednesday, thought Komplett sent it on Saturday, but it was sent today :(Quote:
Originally Posted by Wiker
