With AMD's track record recently the only real confirmation will be when they actually launch.
There are many bios options that can effect the outcome of benches.
HPET is 1 for example, it stops the cpu from throttling back in mulithreaded apps.
Running pi on a cluster, versus a core ( 2 threads ) versus being able to disable a single cluster in a core ( which 99% boards/bios's do not have implemented so resources are not shared ) can all influence the results in single threaded.
Knowing all this tells you one thing for sure, you can make it look worse or make it look better all depending on your knowledge of the chip and or your intentions.
As far as PI it's an antiquated bench and has not been AMD's strong point for quite some time.
Granted some results shown tend to lead to the fact that 1m times are bad but looking at the bigger picture we also know that in many cases you can validate 1000mhz higher in many cases with BD, which would point to the fact that you can run 1m at alot faster speeds than current AMD tech.
Things that make you go hmm like what kind of times will we see at 8 gig or even comparing BD to deneb/thuban when same cooling is used.
Chew, I want to thank you for all the insights you have given on BD. You have made me go from :shakes: to :D waiting for the CPU to come out again. I want to get one, but right now I think it is a big if with MSI updating my AM3 880G board with support. I do not want to drop money on a new board, so I may just end up waiting for the revision (piledriver) to come out.
I think it will be more interesting to see "performance per Watt" instead of "clock vs clock".
Say you have a 1100T system @ 4GHz drawing 600W from the wall in full load, what frequency will a identical FX8150 system (with same components & cpu-cooler) end up with? 5GHz? :shrug:
On top of this it might even run cooler, ending up with another win: a more quiet system...
You can disable the throttling.
http://www.xtremesystems.org/forums/...3&d=1315750652
In ASRock Fatal1ty at least.
Chew,
I know you might not be able to answer this in a timely manner but I have to ask it.
I have a GA-MA790FXT(A) UD5 motherboard $200 USD you sayed that the old CH would support the K15 but not optimal. If it is only a power saving issue could the 790FX also work in this situation?
Thank you for taking the time to answer
I think motherboard sellers want to sell motherboards lol
I am gonna take the under on this one. FP benchmarks are less interesting except in the HPC world. ~90% of what your CPU is doing all day long is integer. FP has long latencies (deeper instructions) and is really only ~10% of the work. So speeding up FP might look awesome on SPEC FP benchmarks, but for desktop apps and most server apps, it gives you little or no noticeable impact.
No, there is a 4-core 4 memory channel interlagos, but that is a server part. It has 2 modules. There is not that much of a benefit for having a single thread running on the module. The overhead from sharing is pretty low, so you get pretty close to the same performance. Running one thread on each module vs. filling the modules means that, to run the same # of threads, you will be doubling the amount of power required because you have fired up 2 modules. You'd be better off in most cases to run it on one module, power gate the other, and get the uplift from turbo because you have more headroom.
Your actual mileage will vary, but the idea that there is a huge overhead for sharing just isn't there. In most cases it will probalby be lightly impacting, if impacting at all.
AGESA is the base code that is given to board developers and OEMs to build their BIOS. The version of AGESA that is used will determine what features are exposed and any performance optimizations that might be available. But just because the feature is in AGESA does not mean that your vendor will take advantage of it, you get the features that they expose to you.
I said before and I will say it again. Public sales prior to launch are not allowed per the embargo guidelines. I can't speak to how the desktop guys would handle it, but back when I used to run business development, if someone was advertising prior to launch, they were not the first guys in line to receive product. Production parts went to the folks that honored the rules.
Considering that ~5% of the market at most is buying top bin parts, you can assume that ~95% are interested in price/performance or performance/watt. Base on that, you are absolutely correct, this would be the most interesting thing to consider in comparisons.
Sabertooth has the same bios options, just not as good onboard sound and doesnt have the special software stuff. From what I remember they both have the same VRM stuff so you should be able to get the exact same overclocks. Sabertooth also has a 5 year warranty instead of 3, however I dont think it doesnt support quad-SLI/crossfire?
...so it's th 19th of Sept, anything New?
