Wow! That's a nice looking build there. Replace the rear fan?
@ iNoXiouZ
overscrewed fans? They are warped, right?
the pump is mounted on a (un)designs pump bracket, i will attach 2 pix to answer your questions.
http://lh5.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8206.JPG
http://lh4.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8255.JPG
The purple and black setup turned out very nice BentQ. Are you using Feser Purple Coolant?
here's a few of my rig at it's current setup, could use some more work, but it's coming along i'd say, as far as the 140mm fan that appears to be backwards, you are correct, i switched it to feed the rads a bit more air, temps are reletively the same, but dust in the case seems to be down a bit...
http://img.techpowerup.org/100721/DSC_0212.jpg
http://img.techpowerup.org/100721/DSC_0217.jpg
http://img.techpowerup.org/100721/DSC_0238.jpg
http://img.techpowerup.org/100721/DSC_0240.jpg
EDIT - PLEASE CHECK 1st post in this thread for image size
Both of you learn to read. 4 pictures. Don't quote pictures.
this is my latest upgrade from my Lian-Li V2000.
CPU:Intel i7 930 OC @ 4.2Ghz
MB: ASUS P6X58D Premium
GPU: EVGA GTX480 SuperClocked+
OC @900/1125/1800
RAM: G.SKILL 6GB (3 x 2GB) DDR3 1600
SSD: OCZ Vertex Turbo
H2O cooling parts:
-Watercool HEATKILLERŽ CPU Rev3.0 1366 CPU Water Block
-Black IceŽ GTX Gen Two Xtreme 560 Highest Performance Radiator
-Feser X-Changer 360mm
-DangerDen GTX480 Nickel Top and Base
-Bitspower Asus P6T/P6X58D NB/SB Water Block
-2X Swiftech MCP355 12 VDC Pump
-XSPC dual Clear Acrylic Pump Top
-EK 150mm Reservoirs with silver strip
-3 gentle typhoon 1150rmp
-4 Yate Loon 140mm Medium Speed
http://lh6.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8764.JPG
http://lh5.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8781.JPG
http://lh3.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8767.JPG
http://lh4.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8774.JPG
REMINDER:
PLEASE DON'T POST MULTIPLE UPDATES of the same case - PLEASE DO start a worklog if you want to show your continuing progress.Quote:
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
Optionally, it would be nice if you could list your water cooling components.
Been working on this one for a while. Sleeving and cable management took forever. It's a CPU only loop in the Fortress special edition red and black case.
http://i484.photobucket.com/albums/r...h_DSC08302.jpg
http://i484.photobucket.com/albums/r...h_DSC08300.jpg
RIIIE motherboard
I7 920 @ 3.8 1.25V
6 GB Mushkin Red Line RAM
2 x Asus Rev.2 5870's in Crossfire
MCP355 with EK X-res top
EK Supreme HF Plexi
Magicool 140 Rad
lol a enermax revolution psu. Yep been there done that. How long did yours take you to sleeve?
I was only able to work on it when I had the time to spare off and on so it's difficult to say exactly how long it took but I'd estimate probably a full 24 hours.
Yes, I've done quite a lot of sleeving, although I had been building my skills primarily on adapters and extensions up to this point. A tip for you, use clothespins and you will save a lot of wear and tear on your fingers/hands.
