Hi,
the new Bios-MOD with new rom's:
ICH9R: v7.5.0.1017 -> v8.6.0.1007
JMicron: v1.06.59 -> v1.07.00
Realtek: v2.09 -> v2.25
http://rapidshare.com/files/200372979/x38dq6.f9x.html
History JMicron:
1.06.60 a. CF card uses the same CHS transfer rule with M-System. (X: not suggested)
1.06.60a a. CF card support CHS Support, few CF cards not support LBA mode
1.06.60b a. Disable Sata Port1 at the controller, which not has sata port1
1.06.61 a. for JMB361 Controller, because CLEVO use pheonix bios, it needs twice checksum of pnp structure.
1.06.62 a.Support Hdd set security freeze lock command requested by ASUS.
b.Add ROM version in Pnp Option ROM Header.
1.06.63 a.Build BCV/BEV independent on Pnp Installation check stucture
b.Clear checksumbyte of Pnp expansion header before building any BCV/BEV
1.06.64 a.Fix JMB360 fails to install Vistal with in-house's AHCI driver reported by ASUS.
1.06.65 a.Update JMB368 Bootrom class code to 0101.
1.06.66 a.Not reference to multi-function trap bit, GPIO0.,
to fix WinXP blue screen issue.
b.Set video mode to mode 3 at Option ROM entry.
c.Fix coding error induced device parity error interrupt.
d.Use R4Eh bit[0] to decide whether enter RAID Setu Menu or not
1.06.67 a.Support raid un-integrity caused by remaping
from single to stripe breaking.
1.06.68 a.Fixed stripe 0 remapping from Port 1 hdd to Port 0 hdd failing to read disk.
1.06.69 a.Using ATA Device Reset command instead of SRST to ATAPI device.
b.Replace space charcter by NULL character in jm_model field
to fix Linux raid failing to boot issue.
1.06.70 a.Fixed failing to boot Vista when PATA hdd uses 40 pin cable.
1.06.71 a.Expand JMB368 Option ROM size
b.Fixed multi-function PATA cable detection codeing error.
c.Pop up a window to ask user whether to del MBR on deleting Mirror RAID
d.Add Sandisk Serial Number Header Data Structure support
1.06.72 a.Randomize MBR.Disk_Signature while deleting MBR
1.06.73 a.Randomize MBR.Disk_Signature while creating a new RAID
1.06.74 a.Patch INT 1Ah issue of ECS Notebook using Phoenix BIOS.
b.Fixed mirror rebuild issue on nVidia C55 north bridge.
c.Hide cursor in RAID setup utility.
1.06.75
a.Fixed hdd programmed under wrong UDMA mode.
b.Add option rom revisin info in rom header.
1.06.79
a.Fix option rom for some special optical disk which assert interrupt abnormally.
1.07.00 a.Add retry to fix pio read the last sector of Segate 1500BG on reboot.
b.Add checking PxSERR.X Exchanged bit to see whether device present.
