Originally Posted by
Falkentyne
Sin and stasio:
I really wish you guys could ask GB to release a new bios to help stabilize the erratic LLC levels, on the P67 and Z68 boards (p67 UD5 B3), especially at high vcores and low/high loads.
As others have said, at low overclocks and low vcore, multi step is okay, but at high overclocks and voltages, it's too erratic...the vcore will swing up a *lot* at very light loads and then go to "where it's supposed to" at heavy loads.
It's not funny to have LLC7 1.425v in Bios, with 1.440v in prime blend, 1.428v in Prime small FFT, and have the vcore jump to 1.484v in a single threaded game >_>
F3G was the last good Bios with very stable Vcore (while LLC1 had big droop at high vcore, LLC2 was always +.024v above Bios setting at full load, which was very nice). But F3G doesn't support 22nm CPU, and has boot loop problems with S3/PLL Overvoltage, and Reset button and Memory fixes needed, so I have to use F7....
Please ask them.
It isn't hard for them to do.
At least they can release a *beta* that REMOVES some of the LLC levels, and maybe puts back 3 decent, reliable LLC levels (like the old LLC2 used to be, but maybe a little less vrise...that would be PERFECT).
Is it to much to ask? Is GB really too busy to make a fix for us?
