MM UFO & Pedestal
http://i645.photobucket.com/albums/u...g?t=1279026692
http://i645.photobucket.com/albums/u...g?t=1279027267
http://i645.photobucket.com/albums/u...g?t=1279027231
http://i645.photobucket.com/albums/u...g?t=1279027184
What blue sleeve is that, kone?
Wow! That is a massive build right there, looks like a cave of computer components...
Hi, it's scythes slip stream fans
http://xtreview.com/images/scythe%20...20fan%2001.jpg
Here's my LIAN LI V1000 PLUS BLACK :p:
http://image.ohozaa.com/i4/2khb1.jpg http://image.ohozaa.com/iy/7tie6.jpg http://image.ohozaa.com/ir/4vg05.jpg http://image.ohozaa.com/ip/0da154.jpg
ey Tipgo do you have a leak in the reserv??? :s
Hello Guys... Some new photos from my rig...
Hope you like it :)
http://img248.imageshack.us/img248/9...c06193h.th.jpg http://img375.imageshack.us/img375/6...c06194m.th.jpg http://img96.imageshack.us/img96/4356/dsc06195y.th.jpg
http://img411.imageshack.us/img411/2...c06196d.th.jpg http://img718.imageshack.us/img718/7...c06197f.th.jpg
http://img130.imageshack.us/img130/620/dsc06199x.th.jpg
http://img686.imageshack.us/img686/5...c06202v.th.jpg http://img807.imageshack.us/img807/8118/dsc06203.th.jpg http://img535.imageshack.us/img535/904/dsc06208i.th.jpg
http://img801.imageshack.us/img801/565/dsc06209.th.jpg http://img14.imageshack.us/img14/4072/dsc06211l.th.jpg
Lots of great pictures and info here.
I just finished watercooling my NZXT Lexa S case. This is a very tight fit. The case is already small and if you're running XFire, it just makes the case that much more crowded. Anyhow, I was able to get it up and running. I still have to do some more sleeving.....what a pain in the a**~
http://i105.photobucket.com/albums/m...100_0090rs.jpg
http://i105.photobucket.com/albums/m...100_0093rs.jpg
http://i105.photobucket.com/albums/m...100_0099rs.jpg
http://i105.photobucket.com/albums/m...SN858131rs.jpg
Koolance CHC-125 (NB Block)
Koolance CPU-340 (CPU Block)
Koolance MVR-40 (V Reg Cooler)
Kollance BKT-HX001 (Radiator Bracket)
Black Ice GT Stealth 240 (Radiator)
OCZ Hydro Pulse 800 (Pump)
Swiftech Reservoir
Fesser 3/8" x 1/2" Blue Tube
Fesser Coolant
:welcome:
Go inter Wow
Then I remember the same.
http://img1.showpic.in.th/pic/9d6/9d...d4413b9ce4.jpg
Thanks: gamethai showpic
Hello all H2O Xtremists, here is my new build. Please enjoy. Thanks.
http://lh3.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8220.JPG
http://lh3.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8291.JPG
http://lh4.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8283.JPG
http://lh6.ggpht.com/_Q78uqzOpXvY/TE...0/IMG_8270.JPG
@bentQ, what coolant/ tubing is that?
the coolant is Feser One F1 Cooling Fluid UV Purple and the tubing is Tygon 3603 3/8" ID (1/2" OD) Clear Tubing.
ขอเสียงคนไทยหน่อยครับ
Show Off :D
THERMALTAKE XASER VI
http://img1.showpic.in.th/pic/4c5/4c...ddee99728b.jpg
http://img1.showpic.in.th/pic/774/77...4167216ab4.jpg
http://img1.showpic.in.th/pic/af6/af...695b62b430.jpg
รังสิต- ขอนแก่น
Thailand
http://images5.bilddagboken.se/90/_u...e14287e7fb.jpg
http://images5.bilddagboken.se/86/_u...99c55fffd7.jpg
rebuilding soon with more rads, temps are a bit high :P
