Originally Posted by
Davit
Yeah that is what I read as well, thank you for the tip.
Here's the setting I have now:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..................: [AUTO]
CPU Clock Ratio ..............................: 9
Fine CPU Clock Ratio.........................:
CPU Frequency ...............................: 4.40Ghz(489 x 9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...................: [Enabled]
CPU Host Frequency (Mhz) .............: [489]
PCI Express Frequency (Mhz) ..........: [100]
CIA2 - disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 1000mv
PCI Express Clock Drive.................: 1000mv
CPU Clock Skew (ps)....................: 0
MCH Clock Skew (ps)....................: 0
DRAM Performance Control
Performance Enhance....................: [STANDARD]
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: [AUTO]
System Memory Multiplier ..............: [2.00D]
Memory Frequency (Mhz) ................: [978]
DRAM Timing Selectable ................: [manual]
Standard Timing Control
CAS Latency Time..........................:5
tRCD ...........................................:5
tRP'.............................................: 5
tRAS............................................:1 5
Advanced Timing Control
tRRD............................................:A uto
tWTR.......................................... :Auto
tWR.............................................:A uto
tRFC............................................:A uto
tRTP...........................................:Au to
Command Rate (CMD) ....................:2
Channel A
Static tRead Value.........................10
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Static tRead Value.........................:10
Motherboard Voltage Control
Voltage Type.
... Manual
CPU
CPU Vcore
.......1.250v*........: 1,5250v
CPU Termination
..... 1.200V*.......: 1,300v
CPU PLL
....1.500V*.......: 1,560v
CPU Referen.
....0.760V*.......: Auto
CPU Reference2
,,0.800V*.......: Auto
MCH/ICH
MCH Core
.....1.100V...........: 1,300v
MCH Reference
.0.760V...........; Auto
MCH/DRAM Ref.
......0.900V...........: Auto
ICH I/O
.....1.500V............: Auto
DRAM
DRAM Voltage
....1.800V............: 2,220V
DRAM Termination .
0.900V............: Auto
Channel A Reference 0.900V............: Auto
Channel B Reference 0.900V............: Auto
Advanced Settings
Limit CPUID Max. to 3 ------------------ : [Disabled]
No-Execute Memory Protect -------------- : [Disabled]
CPU Enhanced Halt (C1E) ---------------- : [Disabled]
C2/C2E State Support ------------------- : [Disabled]
x C4/C4E State Support ----------------- : [Disabled]
CPU Thermal Monitor 2 (TM2) ------------ : [Disabled]
CPU EIST Function --------------------- : [Disabled]
Virtualization Technology -------------- : [Disabled]
