yes same here
yes same here
http://www.newegg.com/product/produc...82E16820146720
they are the blue ones, but if you have the cash, get the extremes. they are the black ones.
http://www.newegg.com/Product/Produc...82E16820146677
i got the blue *hp* modules because they were on special and had a $45 mail in rebate to bring the price to 45 bucks for 2 gigs... but i might pick up a set of these since i am looking for new ram.
Anyone have a link to bios 0217 bios ?? Got plenty of hangs today, when i tried to send some stuff over msn.
I noticed that the Maximus Formula has no tRC memory timing setting in the BIOS...I almost got tRFC confused with tRC in the BIOS and set tRFC to 35 thinking it was tRC...is there no tRC setting for me due to the G.Skill memory?...are the timings that show up in the BIOS dependant on what kind of memory/manufacturer you have?
my guess would be 1.8V as that's the nominal DDR2 voltage
Yeap no 0217 and please do not go off topic for those about discussing for memories.
interesting... i cant set performance level to 7 manually with pull ins disabled, setting to 6 causes a det ram error, putting it to 8 i can post and all is stable. enabling pull ins i can get pl6 at cas5 and pl5 at cas4. it appears that one has to apply the anandtech formula as it seems to be correct after plugging in all the numbers. there is no real guessing at this when the rules of the article are applied and you know your hardware, its just a matter of figuring out to turn on or off pull ins which im pretty sure is one way or the other dependant on strap. we should really read back through this and compile a table of sorts.
NEED MORE SCREEN SHOTS
I copied ALL your settings
I set Clock Twister to Stronger, Dram Static To AUTO, PL = 7
So lets Compare
http://i237.photobucket.com/albums/f.../TEST1_495.png
http://i237.photobucket.com/albums/f.../TEST2_498.png
http://i237.photobucket.com/albums/f.../TEST3_500.png
http://i237.photobucket.com/albums/f.../TEST4_505.png
Why does my L2 Cache suck ass compared to yours?
Double post alert
Looks like teh Rampage is slightly faster
( compare with Zucker2k using MF settings on page 18 )
Using bios 1004 here is are my 4.32GHz settings
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 480
PCI-E Frequency: 110
DRAM Frequency: DDR2-1153
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 35
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Ai Clock Twister : Strong
Transaction Booster : Disabled
Relax level: 0
CPU Voltage : 1.3875
CPU PLL Voltage : AUTO
North Bridge Voltage : 1.47
DRAM Voltage : 2.10
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
Fantastic OC 4.32GHz on water at 1.3875 Vcore bios set. Thx for sharing.
The template is using 1004 Bios right?
Your sig shows you've updated the Bios to Rampage Formula SE Bios 0219.
Correct that is my Maximus 1004 bios settings
Faster for me is PL8/Phases Enabled that PL7/Phases disabled.
But i cannot use PL7/Phases enabled due to CAS 5 limitation at 450@5:6@540
[QUOTE=Grnfinger;2845316]Using bios 1004 here is are my 4.32GHz settings
Extreme Tweaker
FSB Frequency : 480
CAS# Latency : 5
RAS# Precharge : 5
Relax level: 0
DRAM Voltage : 2.10
SB 1.5V Voltage : 1.5[/QUOTE
thanks
@ Grnfinger: Clock Twister was on Auto for my runs on MF. I'm not behind my PC right now, but I'll run with it enabled to see what difference it makes tomorrow.
My "write" and "copy" numbers are better than yours too. I'm sure I can duplicate your read numbers if I run everest tests a couple of times, instead of once. I also think clock twister enabled, will add a few more digits all around. I really want these results to sway me as to which bios to use; so I'll give you all the ram settings for the "secondary, as well as "tertiary" ram settings for the rampage. Could you run rams at these settings:
5-5-5-15-3-35-6-3-8-3-5-4-6-4-6-14-5-1-5-5
Wonder if these to setting will help my overclocking or not ? Using a E8500.
CPU GTL Reference : .63
North Bridge GTL Reference : .67
Ok, one thing that I'm confused about is which phases to enable if I have the ram in the white slots and which if I have it in the blue slots? Anyone got any ideas? I want to try to get PL6 or PL7 with pulled up Phases so it's like PL6 and then lower the timings even more.
How come you guys have a Write speed almost as high as your read speeds?
How come their read and write speeds are nearly even and mine are not?
http://img402.imageshack.us/img402/600/everest2zp6.jpg
my newest numbers ;)
http://img177.imageshack.us/img177/6...emaaxw3.th.png
just reloaded my system again, and started from scratch making sure everything is 100% stable. this is the best ive done yet for a stable system!
http://i48.photobucket.com/albums/f2...22976/1200.jpg
5-5-5-18-3-50-6-3-8-3-5-4-6-46-14-5-1-5-5
