How does Quad BIOS work?
Situation 1: Primary BIOS corrupted, backup bios okay
START
DualBIOS checks
both chips.
No message will
be shown if both
chips are working.
Power On
(BOOT UP) Both BIOS
chips are
working
(1) Primary BIOS Failed to boot
(2) System reset & backup BIOS activated
(3) Backup BIOS realize that main BIOS is corrupted
(4) Backup BIOS invoke to recovery main BIOS
by copying backup to main BIOS
(5) Reset System
BOOT UP
Completed
FINISH
Note:
The above processes are carried out automatically without waiting end-users to press any key.
Situation 2: Primary BIOS corrupted,
backup BIOS corrupted but capable of booting from boot block.
START
Power On
(BOOT UP)
(1)Primary BIOS Failed to boot
(2)System reset & backup BIOS activated
(3)Backup BIOS also find himself being destroyed
(4)Continue to boot from boot block and System search for "Saved" BIOS image in HDD hidden partition
(5)If matched BIOS be founded in HDD hidden partition, recovery BIOS from image saved in HDD
(6)The backup BIOS is recovered and Issue system reset
(7) Restart System (8) Backup BIOS realize that main BIOS is corrupted
(8) Backup BIOS invoke to recovery main BIOS by copying backup to main BIOS
(9) Reset System
BOOT UP
Completed
Note:
From step (4) to (6), it is the process of FINISH
Situation 3: Primary BIOS corrupted, backup BIOS corrupted but capable of booting
from boot block, no matched BIOS found in HDD hidden partition.
START
Power On
(BOOT UP)
(3) Backup BIOS also find himself being destroyed
(4) Continue to boot from boot block and System search for "Saved"
(5) If no matched BIOS be founded in HDD hidden partition, BIOS continue to search for CD-ROM
(6) If matched BIOS image found in CD-ROM drive, that image will be programmed to
the still running backup BIOS image
(7) system reset will be issue continue to boot BOOT UP
Completed
FINISH
So if you can find your motherboard installation cd, put that in your cd-rom drive and try booting.
