ZOMG.. that's better than the best single core opties :slobber:Quote:
You get 50% cpu load?Quote:
If i run prime i get 100% on cpu 0 and 100% load on cpu1 :eek:
You need to set affinity, right click on each Prime95 session in Windows Task Manager.Quote:
Originally Posted by tinuz97
Both cores should be running a 100% load.......
No i do it on a other way: i copie the install dir from prime 95,make from that .exe also a shortcut on desktop so you will have 2.Quote:
I set in the first prime that i must use cpu0,and in the 2nd prime that i start up i set affinity to cpu1.(advanced and then affinity in prime95)
After that i have 2 primes running for 1 core each,that gives me 100% cpu load in taskmanager on both cores,weird that is 50% by you,it must be 100% :slobber:
:worship: Clint's CPU
Hmm, doesn't matter what I do...I get only 50%Quote:
I believe you are wrong guys, all the primes I've been looking at has 50/50 load
Hehe, still alive as well...phui!:slap:Quote:
170 @ 2961 @ 1.59v naked 0550upmw 434
been running at this speed for 3 days now with no issues what so ever. i will go for max 3dmark05 stable tonight,
70f room temp she idles at 33c load 39c
Yep I'm wrong, I just tested it.... Although the task manager graph show each core at 100%, processes shows them both at 50%...Quote:
Shame on me... :slapass: :slapass: :slapass:
So I think the problem is solved. Thanks to everyone for the advice on this. Today I replaced the OCZ modstream with a BFG Tech SLI certified PSU.
no more random shutdowns and I have been dual priming for about 3 hours, plan to let it go another 4-5 hours to be absolutley certain of 100% stability at 2400mhz. Then time to try cranking it up again
hope newegg will give me my money back for a defective PSU
If you lookat the picture I quoted you will see a 165 with a 11 x http://valid.x86-secret.com/show_oc?id=75263Quote:
Originally Posted by nealh
So, how does one get a 11x on a 165?
Luck.Quote:
Originally Posted by Kaiser_Sose
Hehehehe yes thats exactly the right answer.............LUCK !!! :DQuote:
Originally Posted by thunderstruck!
Clint, nice one :)Quote:
Can you please post a grab of your memory settings in cpuz and A64 Tweaker
Thanks ...
ps - what did I miss about Clints cpu? i am 311 HTT Stock ... I guess the 170's 10x makes it look nicer :)
For a internal clock of 270MHz on the sticks :
Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 3
RAS# to CAS# delay (Trcd) - 4 Bus Clocks
Min RAS# active time (Tras) - 8 Bus Clocks
Row precharge time (Trp) - 3 Bus Clocks
Row Cycle time (Trc) - 17 Bus Clocks
Row refresh cyc time (Trfc) - 24 Bus Clocks
Row to Row delay (Trrd) - 4 Bus Clocks
Write recovery time (Twr) - 3 Bus Clocks
Write to Read delay (Twtr) - 2 Bus Clocks
Read to Write delay (Trwt) - 4 Bus Clocks
Refresh Period (Tref) - 3684
( Write CAS Latency (Twcl) - Auto,1 )
DRAM Bank Interleave - Enabled
DQS Skew Control - off
DQS Skew Value - 0
DRAM Drive Strength - 6
DRAM Data Drive Strength - 1
Max Async Latency - 08.0 Nano Seconds
DRAM Response Time - Normal
Read Preamble Time - 06.5 Nano Seconds
IdleCycle Limit - 256 Cycles
Dynamic Counter - Enable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable(4 Bursts)
Sticks on 2.5v
Since I took off the IHS I had to put the sticks in the yellow slots and are having problems with certain dividers.
It could also be the missing "thingie"...:p:
There will be a full monty screenie when I've sorted that out.
First time under phase, had that multi available. Never had that multi under water... either the board, or the cold did it I'd say. Either that or testing lots of different RAM prior to putting phase on.Quote:
Oh and a sh*tload of luck :toast:
my first overclock and first system build, now that the broken OCZ modstream PSU is gone I am finally getting some results
2800Mhz air cooled dual prime stable for two hours
what do you guys think of my temps, are these okay? Do you think the chip will do 3000?
http://img224.imageshack.us/img224/6...post3xp.th.jpg
At idle temps are only 29C for this frequency
NO, its a terrible chip, swap it for my 170 :D
doublepost..
Hehe, don't give it away bro...we wanna see you rip that hat off:D
Spank it some, that maybe will do it...:slapass:
...it's just materia folks, just materia..(and a few bucks..hehe)
Whattaya all reckon, should I try mounting the XP-120?
Kinda dodgy, right?
I just can't have the BT in a vertical position, to much stress on the chip.
Water gonna take a while and I must get back to work/studies...so things must be cleaned..can't have cables and mobos and whatnot all over the desk :rolleyes:
Has anyone mounted the XP-120 on a naked dualcore?
When are you gonna put your 170 under better cooling, Clint? Are you getting water?
Yup, still looking for a good solution...Absolute_0 gave me a few pointers...seems hard to get hold of that G4 storm though...Quote:
..do you have any suggestions?
They have Storm Revision2's now, expensive tho, but they are in stock. Jab-tech has them, idk if they ship internationally.
