i think aqua cuplex xt block is better than Zalman WB4 Gold ?Quote:
Originally Posted by RockfordFosgate
what u think guys? Compare two of them ;)
Asus A8N Sli Deluxe
AMD FX-55
1x Raptor 74GB
2x Corsair CMX 1024 - 3500LL Pro
2x Gainward 6800Ultra Golden Samples
Enermax ESP 660watt PSU
EK-Wave CPU Block
2x EK-FC-79 Sli Blocks
DD Aquadrive HD Block
Laing DDC Pump Plexi Res Top
XSPC 120D X-Fire Radiator
http://www.coolercases.co.uk/images/Stacker/90.jpg
http://www.coolercases.co.uk/images/Stacker/91.jpg
http://www.coolercases.co.uk/images/Stacker/92.jpg
http://www.coolercases.co.uk/images/Stacker/93.jpg
http://www.coolercases.co.uk/images/Stacker/95.jpg
http://www.coolercases.co.uk/images/Stacker/96.jpg
that's so nice! good job :woot:Quote:
Originally Posted by coolmiester
Your Paint job is great:clap:Quote:
Rockrord, very nice/clean!!! Here is my latest build. It is a TJ-07 with a couple mods. Still have some wire management to do. Enjoy pics.
Attachment 55922
Attachment 55923
Attachment 55924
Attachment 55925
Attachment 55926
I like the LCD, anyone looking to put one in...drop me an email if you need any help/advice. I have learned a little about the script and stuff. Attachment 55934
Attachment 55935
Coolmiester, probably your MOD is one of the best MOD of a stacker I've ever seen :)
My compliments, really a great work :toast: .
This is my integration , unfortunately I found only a photo of my Stacker ; in the next day I will try to make some other photos :).
http://img276.imageshack.us/img276/2...gine003pt1.jpg
http://img108.imageshack.us/img108/4...0018vl9.th.jpghttp://img234.imageshack.us/img234/2130/caseix0.th.jpghttp://img444.imageshack.us/img444/9642/case2nn6.th.jpg
here is my comp
it's E6400@3Ghz, Gigabyte DS4, 2x1GB Geil @800Mhz, X1800GTO2 with XT-PE bios @740/1780, 2x250GB WD
WC: Cpu Zern PQ+, NB home made, GPU EK, HDD home made, thermochill PA 120.2, laing D4 and home made reservoir
temps are at load with fans on 7,5V CPU 46°C, GPU 45°C
Cheers Dexther, appreciate your comment - it did go through many changes......not least painting it so it looked just like the standard black one :rolleyes:
and then i thought shiny might be good but wasn't to keen on that either :D
http://www.coolercases.co.uk/images/Stacker/33.jpg
My first water cooled rig: (a w/c 8800GTX is coming soon)
http://www.pbase.com/digifan/image/73763271.jpg
http://www.pbase.com/digifan/image/74256962.jpg
http://www.pbase.com/digifan/image/73627624.jpg
I'm never going back to air cooling.
coolmiester, can you please add your Stacker to the Stacker Slacker thread? That is one sexy lady!
Can i send you my side panels so you can finish them for me?????? :-P PLEASE!
Sorted;) (hope that wasn't to many pictures)Quote:
Originally Posted by phelan1777
Just UPS the side panel over and i'll get right onto it :cool:
That stacker is awesome. Can you see through the window?
Oh yeah sephiroth8748 - its the same thing used on car windows.
Basically you can't see in unless lights are on. I don't have any of the Stacker but this is before and after on a Wavemaster which uses the same stuff
http://www.coolercases.co.uk/images/prod_log/dual_6.jpg
http://www.coolercases.co.uk/images/...bracket_30.jpg
I got a few Wavemasters btw:D
http://www.coolercases.co.uk/images/dualmaster/73.jpg
that is friggin awesome! How do you do that? Would love to do it to my stacker :)
I love that. How did you mount your rad with the fan ontop first? Is that a lian-li pc75, if so how loud are the fans?Quote:
Originally Posted by AuroraProject
Those are yate loons, nearly silent.
Originally Posted by 2k7zero
Thanks, I ran a 1 & 1/4" 6-32 machine bolt through the fan grill, a rubber washer, the fan body, into the radiator. I tapped the rad to 6-32 prior to assembly of course. The case is a Lian Li PC-7077B. The fans are Yate Loons controlled by a Sunbeam rheobus, usually at 7v. All you can hear is the air moving, the fans themselves make virtually no noise.
wuts the best way to install coolsleeves? i just got my 1/2 tygon tubing and some coolsleeve 6xx and these are a :banana::banana::banana::banana::banana: to get on, would wetting the tube help?
or lubing it up ? lol
I just wrapped around the piece of tubing as I went. Then put the tubing on the barbs.
Here is my rig Note in my sig are the parts except the 8800GTX is going in this weekend, Im picking up the EK block tomorrow morning from the Post Office on my way into work.
http://img.photobucket.com/albums/v7...e/DSC01225.jpg
http://img.photobucket.com/albums/v7...e/DSC01229.jpg
http://img.photobucket.com/albums/v7...e/DSC01231.jpg
http://img.photobucket.com/albums/v7...e/DSC01232.jpg
http://img.photobucket.com/albums/v7...e/DSC01114.jpg
http://img.photobucket.com/albums/v7...e/DSC01220.jpg
Here is the Rad assembly out side outside of the case:
http://img.photobucket.com/albums/v7...e/DSC01215.jpg
Hole to adjust the pump settings:
http://img.photobucket.com/albums/v7...e/DSC01111.jpg
And thank god for cool sleeves:
http://img.photobucket.com/albums/v7...e/DSC01110.jpg
That bend will no longer be there when the 8800gtx goes in. Only with the 7950GX2.
Here is my rig!
http://i120.photobucket.com/albums/o...b/DSCI0017.jpg
Sry for shi**y pic, my digi cam is suckin right now for some reason...
