Have you tried LLC disabled?
Also, what were the load temps on that 4200Mhz overclock you showed?
cod4 and cod5 work fine for me with PB ....
Just played around 3hours of COD4, across 3 different servers and no PB issues at all. Perhaps the lazy ****ers have decided to acknowledge W7 early, who knows, but at the mo, it seems to work ok :D
On topic, got my UD5 running BIOS f8b with my i7 920 D0 at 3.6 (18*200) @ 1.2v (1.17v in windows).....is that considered a 'normal'-ish voltage for 3.6??
Yes bud drob becomes huge:shocked:
Temps:
http://img30.imageshack.us/img30/2076/linx4200.jpg
only had i950 for half hour, and 5th boot, but so far loving it...4.6 ghz 1m spi stable at 1.376 vcore.
Edit: holy crap this chip is hot. I think I could run 4.5ghz 24/7 if could control temps. I started linx 5gb, came back it was on the 4th pass, temps were already 95C. Tried prime, 5 mins into it 88C...not running that o/n on my new cpu. So much for 25C ambients, 6 scythe push/pull at 1500rpms on dedicated cpu loop with PA 120.3, my i7 is laughing at it.
http://img198.imageshack.us/img198/1...6001376spi.jpg
nice temps with 1.376 vcore :rofl:
http://img177.imageshack.us/img177/9...5001376pst.jpg
I'm considering getting a Core i7 950 with the UD5, and I got a question. Whats the stock volts for the 950 and whats the max multiplier you can use? Also I'm aiming for 4Ghz on air if I get it and what kind of volts do I need to stabilize the 950?
rge what stepping man?
My batch # 3847B005, got it from newegg.
Snipped in case Gigabyte would get upset, I will ask and then add back if they do not mind.
I like the EX58-UD5 , its very easy to OC and rock solid stable mobo
I'm running my CPU @3.8 v1.12 and my memory @1900 v1.64 Only :)
I also reached 4.0 very easy ( 20 X 200 ) and its very stable , but 3.8 its just fine for my games :D
Was changing the paste on my cpu the other day when i accidently bent a few pins in the socket :shakes: so i've ordered a replacement. Is it a problem to take out the bios chip from the old board and put it in the new one?
Thanks, yeah my delta from air intake 26.2 C to water 32.1 C = 5.9C. I would need a Quad rad or 140x3 to get maybe another 2-3C or delta down to 4C is about the best I could do with fan speed I am willing to use, 1400 rpm 6/push/pull, and maybe another 1-2C with heatkiller, but they are out of stock everywhere. About 4-5C I could gain which would definitely help, 83 would make me much happier than 88 load. I have reseated 4x all within 1C of each other. Biggest issue is 50C delta between water temps and core temps vs 40C delta I had with my i940, not sure if all that is just hot cpu or some of it is IHS/block contact non-ideal.
So far I am settling for 4.4 prime 13hrs stable with vcore 1.34, at least temps are reasonable.
http://img41.imageshack.us/img41/297...primeposta.jpg
a little game on the air
EX58-EXTREME
i7 950@4738MHz air
295GTX@761/1640/1208 air
3Dmark 03 ...105433 :)
http://img244.imageshack.us/img244/5...ure7custom.jpg
EX58-EXTREME
7 950@4738MHz air
3Dmark 05 ...40648 :)
http://img195.imageshack.us/img195/1...ure2custom.jpg
EX58-EXTREME
i7 950@4537MHz air
295GTX@715/1541/1215 air
3Dmark 06 ...29186 :)
http://img132.imageshack.us/img132/2...186customa.jpg
EX58-EXTREME
i7 950@4531MHz air
295GTX@763/1645/1216 air
3Dmark VANTAGE ...24909 :)
http://img198.imageshack.us/img198/2...ure8custom.jpg
Anyone knows when the beta bios (F9x) referred in this thread: http://www.xtremesystems.org/forums/...d.php?t=225264
will be released?
My rig is waiting for such a boost :D
http://img5.imageshack.us/img5/8102/w35204400.jpg
http://img5.imageshack.us/img5/7482/w35204600.jpg
Bclk is almost @ "the wall" (without PCIe tweaking, which I will test in a few hours)
Btw, I also tested the F8bmod bios (with the new AHCI rom) but I lost some options so I reverted to F8b normal.
Those 4Ghz+ benchmarks on air, are they stable? To reach that high on air is quite impressive even if it wasn't stable.
