Originally Posted by
ZenEffect
you should really set it to about 1.9 and re-check your volts again to see exactly how much it over volts. not only is this information good to know, but the word "AUTO" scares the shistuffingst out of me when it comes to asus + voltage. once you know how much it over volts, correct your voltage once again in bios with the adjusted value you just figured out to the factory spec. you could probably squeeze more mhz out of your ram by relaxing your timings on ram, going beyond factory spec on voltage to the ram modules, or a combination of both... in my experience i cant do this by having the voltage on auto.
