my chips sibling lol
http://img371.imageshack.us/img371/6246/003sfg8.jpg
Sometimes in long threads the good stuff gets lost. If you are new here and wondering about what temperature numbers you should believe then check out this test I did a while ago.
http://www.xtremesystems.org/forums/...&postcount=573
This is definately a monster topic , infact its so big i cant really tell what should i be looking for?
So do u have any reccomendations of what batch should i seek for ?
Q807A2xx for the E8400 seems to be the best around.
Here are some results from the other week 5.6Ghz:
http://img253.imageshack.us/img253/4...fastestqk6.jpg
We used a Gigabyte P35T-DQ6 and the ram was Corsair Dominator 1800C7. Was held back by the mobo, this won't be a problem when the Commando arrives later this week. :up:
Thank you very much.
if possible, can someone list out all the batch number and dates they were packed and how well each batch can OC? there are just too many posts on this topic for me to sit here and chart a table from this
my batch is i remember is Q745A356.
True, I think everyone who's been in this thread for a while has seen a bunch of good and bad. But I doubt anyone has an accurate running list of all of them. If they do I'd love to see it.
Also, the definition of good will vary - some want a stable 4ghz OC, some want sky high FSB. If you had a short and sweet set of criteria I bet people would chime in.
For example, I'd like to see like a running top ten best batch list with the following -
batch/fpo | req. Vcore for 8.5x500 | 1 - 2 hours prime & occt stable | temps | Max FSB
luck is still a factor even with 45nm parts.
True there can be range within the same batch. There was another thread recently where someone compared 30 from the same batch - Q808A314 and there were a few bums and gems. But there may be some consistencies like so many out of thirty did xxx.
i have personally compared some within the Q746A batch. some are good most are dud.
TigerDirect just got these in, nice and fresh!!!
http://i156.photobucket.com/albums/t...k/packdate.jpg
4.035 @1.30 idle, 1.28 load prime and occt stable for 1 hour.
Seems to be a nice chip.
Yep,
I've seen some results from E8500 with Q807Axxx batch, and they seemed to clock very nicely (4ghz with lower 1.2xx volts)
just ordered a e8500 and was told it will be a q807a i guess ill have to wait till i get it to see for sure. but do we think these seem to be good batches or should i ask for something else?? they had i think three different ones in stock.. i dont honestly remember what the other 2 batches were.
