o i see,thx you
i been playin with gtl settings for a few hours
for those who have a few errors in memtest and c1 error
the right gtl setting can fix it
use clunk's charts;)
How would we know that we're actually using the best GTL settings?
back to the previous question, how to I extract my bios settings to post here so that you guys may give some opinion on it?
1 more question, I'm thinking of changing my GC cooler to thermalright HR-03. The GC slot ain't seperated quite far, will it be able to fit 2 HR-03?
He's talking about this chart:
http://www.xtremesystems.org/forums/...postcount=2793
Match up your numbers and set the GTL by this.
Find any of the posts in this thread that have their settings and print them, then copy the text and use code tags on them. You'll need to input the data by hand AFAIK. Just use your printed copy while you're in the BIOS and write down any settings that are different.
GTL REF is 67% for 65nm chips... What is "best" % for 45nm chips ??
i finally got my other 4*2gb kit back the other day so im going to try again over the next few days overclocking 4*2gb :D
I had some strange things happen with GTLs after moving from air cooling to phase.
With Air cooling I had the GTLs at 120, 120, 120 with CPU VTT at 1.603V but when I switched to phase I can't boot into windows with GTLs Enabled... :shrug:
Hello, this is my first Post here.I´m a German DFI X38 "User" with an Q6600
bought Pretested @3,6.
O.K. here´s what i have to say about the new Bios and VCore and enabled/disabled Special Add.
For those who want to use C1E and/with special add with the new Bios.
Steps: In Bios Highlight Vcore and then press ENTER ; By scrolling down choose temporarily a voltage over 1,3V ; Do not save&exit , then go to the special add Value because now it is chooseable and with enter & scrolling get the Voltage percentage you need ; Go Back to the vcore and choose with Enter & Scrolling the "Auto" value again. Now you´ll see that the
special add still hold the value......save & exit and that´s it:yepp:
Regards Neon Knights
Be careful with VTT over 1,5v, the guys (or more specific Raja) over att Anandtech fried their qx9650.
http://www.anandtech.com/weblog/showpost.aspx?i=428
someone can tell me the distance beetween the two holes of the NB please ?
http://www.exoid.com/wp-content/uplo...3/img_1136.JPG
i need the distance beetwen holes we see on this HS ..
Heh, great tip ;)
According to some tests and my own findings, for 45nm chips it's about 55-57% BUT it's my not for 100% sure...
Here's an example using E8200 on DFI P35 LanParty (link)
4200MHz - 8x525MHz, VTT 1.2V, VCORE 1,45V
GTL - AUTO - restart during OS load
GTL - 85/85/85 - restart during OS load
GTL - 76/75/76 - SuperPI 32M - error just after start
GTL - 73/72/73 - SuperPI 32M - error after loop1
GTL - 70/69/70 - SuperPI 32M - calculation done. Goin' further...
4304MHz - 8x538MHz, VTT 1.2V, VCORE 1,45V
GTL - 70/69/70 - SuperPI 32M - error jus after start
GTL - 69/68/69 - SuperPI 32M - error jus after start
GTL - 64/63/64 - SuperPI 32M - error after loop8
GTL - 62/61/62 - SuperPI 32M - error after loop12
GTL - 60/59/60 - SuperPI 32M - calculation done
I used it just for orientation to have good "start point"... then found stability and gave up OCing :rofl:
i used faster method:rofl: :rofl:
i used memtest test 5
i set ram aggressive lots of settings i averaged 200 errors then i found settin with -20 errors n tweeked
every cpu n every board n ram react different
dual core cpus are verry forgiving on bad setting not quads
My Q6600 GO stable at 3.8Ghz with a VVT of 1.44V
OK, I am really starting to hate this board. I can't seem to overclock it worth a damn. I've tried multiple settings from other users in this thread trying to get it to run @ 3.6 GHz, but most of the time it won't even boot. Best I can do is 3.0 GHz with about 30 minutes of Prime 95 stability before the system locks up and I have to reset.
Can someone look over my settings and try to make some suggestions? Here is all the hardware:
- Q6600 G0 L743 1.25v
- 2 x 1GB G.Skill PC2-6400 HZ's
- HIS HD3870X2
- Thermaltake ToughPower 850W
- 4 x 250 GB Seagate 7200.10's in raid 0/5
- Noctua NH-U12P heatsink
- Stock heatsinks on NB, SB and VGA
- BIOS 3-14
And here are the settings I used at 3.0 GHz:
Code:CPU Feature Page
Thermal Management Control................Disabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Disabled
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................9x
CPU Clock.................................333 MHz
Boot Up Clock.............................Auto
DRAM Speed................................333/800
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.32500V
CPU VID Special Add.......................Auto
DRAM Voltage Control......................2.150V
SB Core/CPU PLL Voltage...................1.510V
NB Core Voltage...........................1.504V
CPU VTT Voltage...........................1.305V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................110
CPU GTL 0/2 REF Volt......................110
North Bridge GTL REF Volt ................110
DRAM Timing Page
Enhance Data Transmitting.................Auto
Enhance Addressing........................Auto
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................4
RAS# to CAS# Delay (tRCD).................4
RAS# Precharge (tRP)......................4
Precharge Delay (tRAS)....................12
All Precharge to Act......................Auto
REF to ACT Delay (tRFC)...................Auto
Performance Level.........................Auto
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................Auto
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Auto
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................Auto
DIMM 1 Clock fine delay...................Current 156ps
DIMM 2 Clock fine delay...................Current 534pd
DIMM 1 Control fine delay.................Current 601ps
DIMM 2 Control fine delay.................Current 356ps
Ch 1 Command fine delay...................Current 868ps
Ch2 Clock Crossing Setting................Auto
DIMM 3 Clock fine delay...................Current 156
DIMM 4 Clock fine delay...................Current 467
DIMM 3 Control fine delay.................Current 445
DIMM 4 Control fine delay.................Current 434
Ch 2 Command fine delay...................Current 868
Ch1Ch2 CommonClock Setting................Auto
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
t_ski try 1.45"real" cpu vtt bump the voltage of cpu 1.45
set gtl manually to 130-120-100 should be good for 3,6
bump vdim to 2.2v
Q6600 - 450x8, 2x1GB
http://www.edgeofstability.com/image...0/3600_a_s.jpg
http://www.edgeofstability.com/image...0/3600_b_s.jpg
http://www.edgeofstability.com/image...0/3600_c_s.jpg
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Enabled
CIE Function..............................Auto
Main BIOS Page
CPU Clock Ratio...........................8x
CPU Clock.................................450 MHz
CPU VID Control...........................1.37500V
DRAM Voltage Control......................2.190V
CPU VTT Voltage...........................1.327V
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
All Precharge to Act......................5
REF to ACT Delay (tRFC)...................26
Performance Level.........................8
MCH ODT Latency...........................2
Write to PRE Delay (tWR)..................14
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............4
Ranks Read to Read (tRDRD)................5
Ranks Write to Read (tWRRD)...............4
Read CAS# Precharge (tRTP)................3
ALL PRE to Refresh........................5
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Enabled
Channel 1 Phase 2 Pull-In.................Enabled
Channel 1 Phase 3 Pull-In.................Enabled
Channel 1 Phase 4 Pull-In.................Enabled
Channel 2 Phase 0 Pull-In.................Enabled
Channel 2 Phase 2 Pull-In.................Enabled
Channel 2 Phase 3 Pull-In.................Enabled
Channel 2 Phase 4 Pull-In.................Enabled
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current 67ps
DIMM 2 Clock fine delay...................Current 445pd
DIMM 1 Control fine delay.................Current 512ps
DIMM 2 Control fine delay.................Current 267ps
Ch 1 Command fine delay...................Current 779ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current 67
DIMM 4 Clock fine delay...................Current 370
DIMM 3 Control fine delay.................Current 356
DIMM 4 Control fine delay.................Current 345
Ch 2 Command fine delay...................Current 779
Ch1Ch2 CommonClock Setting................More Aggressive
Q6600 - 450x8, 2x2GB
http://www.edgeofstability.com/image..._prime_a_s.jpg
http://www.edgeofstability.com/image..._prime_b_s.jpg
http://www.edgeofstability.com/image...0x8xp_06_s.jpg
Main BIOS Page
Exist Setup Shutdown......................Mode 1
Shutdown After AC Loss....................Enabled
PCIE Clock................................100 MHz
CPU VID Control...........................1.3875V
DRAM Voltage Control......................1.985V
CPU GTL1/3 REF Volt.......................N/A
CPU GTL 0/2 REF Volt......................N/A
North Bridge GTL REF Volt ................N/A
DRAM Timing Page
T2 Dispatch...............................Enabled
RAS# Precharge (tRP)......................3
Precharge Delay (tRAS)....................15
All Precharge to Act......................4
REF to ACT Delay (tRFC)...................48
ALL PRE to Refresh........................4
DIMM 1 Clock fine delay...................Current 89ps
DIMM 2 Clock fine delay...................Current 456ps
DIMM 1 Control fine delay.................Current 534ps
DIMM 2 Control fine delay.................Current 289ps
Ch 1 Command fine delay...................Current 801ps
DIMM 3 Clock fine delay...................Current 89ps
DIMM 4 Clock fine delay...................Current 400ps
DIMM 3 Control fine delay.................Current 367ps
DIMM 4 Control fine delay.................Current 356ps
Ch 2 Command fine delay...................Current 801ps
zsamz and Praz, thanks for the advice. I'll see if I can try them out later tonight.
Praz, that first list of settings (2 x 1GB) is not to far off from another list of settigns you posted earlier. I tried those without luck (wouldn't even boot). I think the new ones have one step up on vcore and Setup Shutdown Mode is changed, and about half of the ram timings are different, but that's about it. Where those a copy and paste from another run you did, or specific suggestions for my setup? Just curious - I'll still give them a shot. ;)
lol Actually I think it was the 2 x 2GB settings you just posted. They seem the same.
BTW, why do you suggest having all the PM stuff enabled? Doesn't that effect the stability a little?
