Originally Posted by
hammer_of_thor
First, hi all.
I am a proud owner of Rampage II Extreme Motherboard for 6 months now and there has been no problem until yesterday.
The computer was working fine until it froze and stayed like that, after a reset the computer wouldn't post and LCD poster said "LOCKED" right away.
I tried clearing BIOS, tried 3 graphic cards, tried two CPU-s (both i7 920), two power supplys, changing the RAM slots and booting with only one RAM stick, taken the BIOS battery out for 20 minutes. Everything I could think off I tried but the moment i started the computer LCD poster would say LOCKED every time. The fans spin, HDD works but no post.
I also noticed green RAM LED and CPU LED would no longer turn ON (green LED's that show the CPU and RAM voltage. When starting the computer only BIOS LED would turn on.
I consider myself a power user and everything is connected properly
System specs are:
Asus Rampage II Extreme
Intel i7 920
ThermalRight Ultra 120 Extreme Black CPU cooler
2x2 GB G.Skill DDR3
nVidia GTX275
Corsair HX620 PSU
The system was slightly overclocked to 4 GHz with moderate voltages (was stable for a long time before that), no extreme overclocking was performed
My guess is that the MBO is dead, but i cant be sure.
I've taken apart the whole system 4 times and put it back together but still the same, no post, LCD poster says LOCKED, and CPU and RAM LED's are not turned on
The MBO is under a warranty in a IT store in Croatia but before taking it there let's see if the problem can be solved here.
-Hrvoje
