Flashing the bios with a USB key
Originally Posted by
Danger30Q
Is there anyway to update the BIOS without having to use a floppy? I don't own one and have not needed a floppy with previous motherboards in order to flash the BIOS.
Please tell me there is another way. I tried using the FlashMenu through the uGuru but it says this motherboard doesn't support FlashMenu.
I have just done this and know it can be a little confusing so I thought I'd try to give a little guide for using a USB key to flash the bios. This is assuming you have basic knowledge of the bios.
1) Place your USB key in your machine.
2) Go here, download the zip file and follow the guide. First thing you need to do is make your USB key a bootable device which is what this guide shows you how to do.
3) Next place Bios files on the now bootable USB key, also look to Ace's guide in his sig for additional info or just click here.
4) Once your USB key is all ready, re-boot your machine, go into the bios and here's where it get's a little tricky because there are a few options that will need to be changed.
5) First you need to change the "First boot device" option to USB-HDD
6) Next under "Hard Disk Boot Priority" you'll need to move your USB key to the first in the selection using your +/- keys on the number pad (if I remember correctly :rolleyes:)
7) Next you need to go into your USB settings and look for "USB Keyboard support Via" and change that to Bios from OS. Also somewhere in here there is an option to change the USB key from "Auto", to HDD, switch this to HDD.
8) That should do it if I remember correctly. Next all you should have to do is reboot the machine then at the "C:" prompt type: RUNME.BAT and follow the on screen prompts, also look to Ace's guide for further info.
Note: I will clean this guide up a bit and post pics this weekend when I have the time. This was all written off the top of my head so if you see something that I have missed please let me know. Also this was done on XP 32bit, I'm assuming it wouldn't matter for Vista, correct me if I'm wrong.
