Asus boards with vdroop mod have 0 , and thats my target if possible. Anyway 0,02 is good, and with that mod... :slobber:
Got this e-amial from Intel regarding the C1E issue:
Jesus Christ.. why the f*#k would I ever want the vid to change on an overcloked system?! This is scary stuff for me at least.. If vid`s changing values, this really gives me chills down my spine..Quote:
Hello again, Jorn,
Thank you once more for contacting Intel(R) Technical Support.
Regarding this situation with your Intel(R) Desktop Board D975XBX2, please be aware that this multiplier difference detected could be related to the TM2 (Thermal Monitor 2) technology, which is supported by both your chipset and processor.
This enhanced TCC provides an efficient means of reducing the power consumption within the processor and limiting the processor temperature. Thermal Monitor 2 is supported in your unit of the Intel(R) Core 2 Duo processors.
When Thermal Monitor 2 is featured, the enhanced TCC causes the processor to adjust its operating frequency (by dropping the bus-to-core multiplier to its minimum available value) and input voltage identification (VID) value. This combination of reduced frequency and VID results in a reduction in processor power consumption.
At this point, there is no option to turn off the feature. It is enabled by default when a processor that supports it is detected by the BIOS.
Please do not hesitate to contact us again if you need further assistance.
Sincerely,
Paul C.
Like I care?! Electrical power is really cheap here in Norway.. And if other 975x bords/brands don`t have this problem, why can`t the invetor of this CPU+chipset find a solution to eliminate this issue?!! or at least give me the option to disable this function?! (beside 3.party solutions) And as most people know, reduction of the frequency gives minimal power saving, lower voltage (Vcc) does, but stay away from this option on an OC`ed system!Quote:
I want control my self, and if other brand`s can do it on the same chipset why can`t Intel?! Does anyone who know the phone number to companies like DFI or Abit and please give it to the Intel support staff so we can resolve this issue?
So my CPU is trotteling because of the heat (TM2), and the heat is most intensive at IDLE state??! Where is the logic here? There are shurly som really bright heads working at Intel`s mainbord division :p:
I give up.. This board and it`s support staff will shurly make me tell everyone to avoid this board.. Period! Do I look like a 5 cent whore? If not, then why are Intel trying to fu*k me like one?!
New everest is showing much lower tempature than TAT and somewhat lower than the new core temp.
TAT got up to a reported 81c:slobber:
I have some shin etsu ordered to replace this AS5 junk.
Really am hoping to see 3.6 ghz at least post.
System would post at 3.375 but error out on orthos.
I have had 3.3 running orthos for 9 hours stable overnight but dropped it down to 3.0 for fear of the high temps. :eek:
Attachment 56883
Attachment 56884
TAT Attachment 56885
coretemp Attachment 56881
That bull:banana::banana::banana::banana: about the TM2 can easily be disproved by someone using phase or Dry Ice and checking what cpuZ says then. It cant be TM2 its just their board not turning off C1E ive checked my other boards and none of them clock back with CpuZ1.39, not to mention the temperature they are talking about is at like the 60C mark for that TM2 to kick in no?
This is my first post here on XS forum so hi to everyone :) Also, good job with this massive XBX2 topic that I followed from day one as a owner.
I would like to add something about the C1E / TM2 issues :
Download http://cpu.rightmark.org/products/rmclock.shtml then run it. It's nearly useless for tweaking since C2D is not 100% supported but the best thing with this is that it will show what PM (Power Management) features is enabled or disabled. With this software, we can see EIST, TM1, TM2, ODCM and CxE and if you run this software on the XBX2 with C1E "disabled" in the BIOS, RMClock will still show CxE in blue, meaning it's enabled. However, TM2 is still in black.
I also got further as testing the "throttling" point and I was never able to throttle my E4300 at 3.5 GHz, only got reboots each time CoreTemp 0.94 display 75-77C, which is not a TM1/TM2 feature. Normally, if TM2 is working fine, the computer should be still running, only with lowered multiplier and voltage to keep the temperature in check.
This is the perfect proof XBX2 has a bad bug with TM2 disabled and C1E enabled by default. Show this data to the stupid Intel engineers and tell them to fix this.
Some more infos about those features can be found in http://www.digit-life.com/articles2/...res-core2.html :cool:
Sorry for all the "nasty" words in my last post, but I was a bit frustrated.. But anyway, can`t we sum it up in one really good answer and I (or others) can send Intel. Get a really detailed description of the problem and also prove the fact that the C1E + EIST + TM2 conclusion they give us don`t make any sense?
My english is not the best in the world as I normally speak norwegian, so it would be of great help to me if anyone can write the reply and I will send it ASAP to Intel :fact:
The last link explain everything very well so a good idea would be to send this link to them and explain why their explanation doesn't make sense. I don't have time to write a summary but I'm sure someone will do.
I'm even willing to send a email to Intel if someone tell me at which address :fact:
Ive tested P5W DH, and P5B Dlx..... and I turn C1E on with them and they go 2.4ghz with 400x6 multi....If I goto the bios and turn C1E off and check again with CPUZ 1.39 I read 3600mhz 400x9.......
So Its obviously an error with intels bios.
Anyone use this memory? I was just wondering how high you got it on the BX2. I am currently using it now. Also what kind of memory chips is it?
http://www.patriotmem.com/products/d...&id=317&type=1
Yes it`s bull:banana::banana::banana::banana:, I have watercooling so heat is not an issue. I think it is quite funny/ironic that the company that invented the board+chipset+cpu can`t resolve this "bug".. while Abit, Asus, DFI and all other MB makers can on the same config??!
It ALL boils down to this: INTEL DOES NOT RESPECT ENTHUSIAST/POWER USERS :(
ahh so it was all a ploy to steal his avatar??? :D
lol guys, this beauty is only mine :D
Not true. I had 3 out of 4 1GB sticks of OCZ Titanium Alpha PC2-8000 die on me recently. They stopped booting at stock voltages AND anything in between up to 2.3v (their rated voltage). Don't know why they died, it could have been this board or the Asus P5W-DH that I junked for this board. I *think* my OCZ modules also contain D9GMH (if not GMH it's some other D9) chips... perhaps they don't play nice together. :(
They are in RMA land at the moment.
The X-fi is a great sounding card. I always prefer a nice quality card to onboard audio. Yes it uses less CPU cycles (not really noticeable these days with these nice CPU's), but I don't think Creative's current Vista driver supports EAX 4.0 yet. Regardless, the card sounds crystal clear. I recommend picking one up.
I got a different response from Intel regarding the C1E bug. It seems they are completely denying it now.
Thank you for contacting Intel(R) Technical Support.
First at all, even though the C1E and the Enhance Intel(R) SpeedStep Technology are related, they are not the same. C1E is a feature that refers to the Enhanced Halt State and the Enhance SpeedStep Technology allows the system to dynamically adjust processor voltage and core frequency, which can result in decreased average power consumption and decreased average heat production
Then again the operating system handles the power management for the different devices within the system, you can try going to power options in the control panel and set the power schemes to always on.
We do not rely on what third party software states, that is why we would recommend you to run the Intel(R) Processor Identification Utility to properly identify your Intel(R) processor and its features.
The Intel(R) Processor Identification Utility was developed by Intel(R) Corporation to enable consumers the ability to identify and, in some circumstances, determine if their Intel(R) processor is operating at the correct speed intended by Intel(R) Corporation. Beginning with the Pentium(R) processor, this utility provides consumers with the ability to determine standard CPU identification of Intel processors. In addition, supported processors can utilize the Intel(R) Processor Identification Utility to help determine if a processor has been over-clocked.
You can download this utility at:
http://www.intel.com/support/processors/tools/piu/
Then again, you can try running the latest BIOS version for your motherboard. You can get this update at the following link:
http://downloadfinder.intel.com/scri...ProductID=2578
This was their reply to me after I told them CPU-Z and Everest was how I determined C1E wasnt disabling. I dont even know how to politely respond to this. :rolleyes:
Came across this yesterday:
Creative ALchemy Project allows you to run your favorite DirectSound3D games on Windows Vista as the developers intended - with full hardware accelerated 3D Audio and EAX support! This is done by translating DirectSound calls into OpenAL. In order for this to happen, a couple of files need to be installed into each game directory. This is handled automatically by the ALchemy installer - but can also be performed manually by advanced users.
Requirements:
- Windows Vista
- SB X-Fi * series soundcard with native OpenAL 1.1 Support * Excludes SB X-Fi Xtreme Audio
Download here: http://preview.creativelabs.com/alch...hemy%201.3.zip
HELP!
I got my fan back from Enermax today and went straight about installing it. Easy enough. Then I tried to boot.
Arrrgghhhh! I kept get the message about failed POSTs, press 'Y' to go to BIOS, 'N' to use prior settings. No matter what I did, 'Y', or 'N', I could not get it to boot. :eek:
Thinking that the fan was pulling extra Wattage (I have a Corsair 620), I put extra voltage to the memory, vCore, everything, but nothing worked. Finally, by going back to no overclocking at all, I was able to boot.
So then, I went back in, restored my old overclocking (in my sig), and booted. Got the 'Y' or 'N' again. So then, I tried this old trick I had learned when I was overclocking last week. I would get to the 'Y' or 'N' message, press 'N', quickly press the reset button on my case, and then hold down the pwoer button. That worked! I booted to here, buyt my memory timings are 667 5-5-5-12 not 533 4-4-4-12.
I am going to jumper the BIOS right now, but will be back to see any replies. Please, gtj, anyone, help me!
