Spontaneous reboot problem
I’m hoping the knowledgeable folks on this forum can help me with this problem I’m having, on my first build ever. While it’s my first build, I will say that I’m very familiar with components, and how they interact, but this problem has stumped me.
Specs:
Antec P180 case with 4 Yate Loon D12SL fans (2 fans in push-pull on Scythe Ninja, 1 intake in front upper chamber, 1 intake in lower chamber)
Seasonic S12 HE+ 550 Watt PSU
P5W DH Deluxe 1.85 MCH version with 1506 bios (Thermal pads and covers removed from NB and SB heatsinks and replaced with AC5)
Intel C2E X6800 @ 3.20GHz (266 x 12)
2GB (2x1024) Mushkin XP2-8000 DDR2 RAM @ 800 MHz (2:3 divider 4-4-4-12)
HIS Radeon X1950 Pro
WD 500 GB SATA drive on SATA 3 channel
WD 160 GB SATA drive on SATA 4 channel
DVD-ROM on IDE channel master
BenQ DW1640 DVD +RW on IDE channel slave
The problems are:
1. System becomes unstable and spontaneously reboots (no BSOD) whenever 3D gaming or 2D video rendering occurs. The system is perfectly stable, and seems generally fine when idle, and even runs Orthos without fail. I was also able to transcode a 300MB Xvid to DVD format without any problems. Whenever I play a video or play a game, the system will tolerate a few minutes, then reboot without explanation (yes I’ve already unchecked “automatically reboot” in the advanced settings of My Computer).
I thought this was maybe due to my graphics card being faulty, so I swapped with another one and the same problem occurred. Core Temp and Everest reports the proc is running at around 41C at idle, and I’ve never seen it above 55C at load. Motherboard (SB) temp is reported at 39C in Everest. I’ve ruled out temps being the problem. I have latest Catalyst driver, but not latest MB BIOS due to the inability to adjust multiplier up on my X6800 with that bios. I’ve disabled HyperPath, DRAM throttling, Speedstep, etc in BIOS, but all voltages are at auto except for RAM which is at 2.2V. I figure it could be faulty MB or RAM at this point, but MemTest 86+ didn’t report any failures. I have updated the BIOS a few times, but never cleared the CMOS via jumpers, just used the /pbnc /n switches in AFUDOS. Any suggestions for how I can stop my system from spontaneous reboots?
2. Cannot seem to get stable even at 333 FSB, even with relaxed memory timings, let alone reach anywhere near 400 FSB for 1:1 memory operation. Not even trying to hit super aggressive clock on my X6800 (3.46GHz). This is not my main problem, just more of an annoyance as I’d prefer to run memory at 1:1. I can’t seem to hit the rated speed of 1000MHz on my Mushkin RAM and be stable, even at loose timings. I’m assuming this is due to dividers. Do I need to drop multi way down to 8 to run at high FSB?
