Looks like a San Ace 101.
Hi Obitus, nice Cabble management
How hot is the northbridge and pwm heatsink?
Its easy, stick the finger onto it :poke: (in load of course:p: ) Im interested in this mboard
tried cleaning up my wires a bit, really need a corsair modular psu, going to buy the window sidepanel on newegg for 30 bucks since i cant do one myself cause i suck at modding stuff lol
http://img299.imageshack.us/img299/8207/img4030cq5.jpg
whoa! 11 fans (that i can see). you wanna try lapping heatsinks and use good thermal paste, with better heat transference you can afford to lose some fans and have other fans spinning slower ... thats what i've done. up until yesterday my system was silent (apart from the raptors grinding away), but one of the nexus fans is giving me a whirring sound now
80mm on the right side of case cooling back of motherboard too :D
:P but my temps are great on both gpu and cpu plus i always have headset on so noise really doesnt bother me i never tried lapping kinda scared of messing up heatsink :P cpu @ 3.6 idles 34 on two core and 37 on other two load is about 55c on prime and gpu idles 34c and load is about 45 :)
^^ Your Fan-Puter is in need of some work Cuz...
It's F---ed
you should try lapping, there's loads of metal to work with considering your just working with micro layers. temps will deffinately go down, i have only 5 12cm fans, 3 x 1000rpm, 1 x 800rpm, 1 x 1200rpm and my idle and load temps are well below yours. if i put faster fans on i shave a few more degrees but imhappy with my setup for now.
upto you though, sound is a thing for me, maybe its my ears cos 2 things i want is a quiet machine and quality speakers / headphones
i even modded the fan / cooling on my digital tv set top box, and put in sound proofing cos of the HDD. i think im a bit fussy. time will tell, im just modding a dell xps case to standard atx, gonna thread it soon.
man u have awsome nick !!
like a pile of junk :D
I second his suggestion, even though I didn't lap my HS because it is working fine for me right now. It will definitely help with cooling. Also you could try to find which fans are not doing much of anything. Like the one under your tunig tower, I don't think it does much other than make more noise.
Also Burns may I suggest you mod the case to inverted-ATX, much less work and better cooling most likely.
you have so many ccfls but your camera has no flash ????
This pictures from captured AVI by videocam.
OCZ« , your case is amazing. Never before have I seen such translucence.
:D
http://img152.imageshack.us/img152/2...0510dk1.th.jpg
My old setup when i tried the 320mb and the 640mb in SLI. Didnt work :(
Current setup
[img=http://img172.imageshack.us/img172/111/img00293lu9.th.jpg]
Any new CPU coolers out? I know the TRUE is still very very good, but it's kinda getting old on me. :shrug:
