OK, guys. Hello to everyone, I'm new here spending 1 USD for possibility to ask 1 question ;-)
What's that from ?
http://imageshack.us/a/img7/1296/pciey.jpg
Any replies appreciated, except "from this plug" :)
What's that from ?
What do you mean from? Do you mean where can you buy it?
That is heatshrink from MDPC made by psychosleeve
http://de.mdpc-x.com/mdpc-sleeve/schrumpfschlauch.htm
using german link cause international one is only on when he wants it to be on
Thanks for the info.
I've got something similar, but it doesn't look this way after shrinking, so it's why I asked. More likely I'd say it's kind of plastic, not Schrumpfschlauch :)
http://i.imgur.com/YrjEZ8h.jpg
I received my first MDPC-X package yesterday (June 17, 2013 5:45 PM UTC-06:00).
Contents:
1 x MDPC Crimping-Tool + 160 Crimps
Thank You Nils
I?m about to sleeve my corsair AX760, anything i should know? Strange cable setup etc?
All Corsair AX750/850/1200 series psu's have a particular pinout, most of the time (at least on my old AX850) you'll have to deal with 2 wires going into 1 pin (for 6/8pin gpus cables and 24 pin cables mostly). If you like the look of 2 wires going into 1 pin and you're good at sleeving then go for it. I personally haven't found double wire shrinkless sleeving that hard (I followed lutro0 custom's guides on youtube), but I didn't try the classic sleeving method with heatshrink.
Anyway, if you really want a clean look with a 1:1 pinout go with Silverstone PSU's, really solid PSU's and the best for sleeving.
You'll have to do some custom cables for those double wires... It's not hard, just need some cable, crimps and soldering iron
This thread needs to be updated,pics not loading ! = /
I want to buy Cable Series
Simple guide by me or a more detailed video.
http://www.hardwarecanucks.com/forum...ry-thread.html
http://i18.photobucket.com/albums/b1...xport-1-72.jpg
