thats what i thought :(
anyways, i re-found afudos just to see where i got it from. its from south africa :D
Anyone got some voltage settings they are using? I will post mine up soon, but I am still trying to get every last bit outta this board. I would really like to get 475 stable, which is getting closer.
Where can i find bios 0217 ?
Quick Q: Blue or White Dimm slots for the best OC-ability:Vdimm and stability?
well, after a bit of tweaking im relativley happy; howver i think i can get a little bit more oudda my hardware...
http://img152.imageshack.us/img152/2...chemem2pd7.png
here are my settings...
http://img85.imageshack.us/img85/346/cimg1245ts7.jpg
http://img247.imageshack.us/img247/403/cimg1246pq5.jpg
http://img187.imageshack.us/img187/5221/cimg1247zv6.jpg
anyone have suggestions on how i can improve from here????
CPU Voltage : 1.475
CPU PLL Voltage :1.6
North Bridge Voltage :1.51
DRAM Voltage : 2.26
FSB Termination Voltage : 1.51
South Bridge Voltage : 1.1
Loadline Calibration : enabled
CPU GTL Reference : .67
North Bridge GTL Reference : .67
DDR2 Channel A REF Voltage : auto
DDR2 Channel B REF Voltage : auto
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.5
took the template from the maximus thread but whatever
@ericab
play with the transaction booster, i was able to get pl5 out of my ram *set as 6 but pull ins are enabled to make it 5*
everything is at stock and it still happens every few re-boots
could my voltages be too high?...I have all the voltages set to 'Auto' in the BIOS but according to PC Probe my Vcore is 1.20, NB= 48C (1.36V), SB= 44C (1.07V)
what should I set my NB, SB, CPU and CPU PLL voltages to for optimal performance at stock settings?
zen, i tried playing with the booster..... ANYTHING less then what its already at, is an automatic DET RAM~ :(Quote:
@ericab
btw my ram is Crucial Ballistix PC6400....
here are my voltages also.
CPU Voltage : 1.3625
North Bridge Voltage :1.45
DRAM Voltage : 2.20
FSB Termination Voltage : 1.36
South Bridge Voltage : 1.075
CPU GTL Reference : auto (for now)
North Bridge GTL Reference : auto (for now)
Same here , I'm so :banana::banana::banana::banana:ing sick of that Det Ram. Had is sorted on the MF now its back and hard as hell to sort out.
If I run Trans Booster on anything but Auto I get the hang.
Yeah, you guys run lower NB voltage, I cant seem to get 8GB any lower than 1.61v-1.63v
Thanks for the info, I will see what I can do with it.
@Grnfinger try booster manual with dram static control disabled..
I will give it a shot
key things i noticed to get trans booster to work *for me* were
i HAVE to be at cas4 for pl below 7
i HAVE to set the fsb strap to 400
if i manually set pl to 5 i get system hang
if i manually set pl to 6 and do pull ins for pl of 5, it works.
now imma go eat some pizza
My bios settings.
No luck still get the hang
Running ram @ 5-5-5-15-3-35-6-3
Dram Static = Auto
Clock Twister =Stronger
Trans Booster =Auto
http://i237.photobucket.com/albums/f...ger/RF_Ram.png
Not bad at all but I would like to play with the setting. Anything but Auto and it wont boot
