LOL. Sve po starom, na zalost.
Lol! :cheer2: Ziveo Balkan!Quote:
Originally Posted by lukija
lol you really in japan? :P
Yep. Zdele dezuje. ;) :p:
I made a little tool, it is for nForce 4 only, you can change clock from 100 to 600MHz, so beware, do not push too much. It is very precise (0.1MHz steps) hance slow. I takes a couple of seconds if you change clock for 100MHz up or down. If it works OK , it will be implemented in nexte version of A64Info.
http://avala.yubc.net/~lukija/nF4ClockTest.exe
thx ;)
downloaded ;)
can you make the bus clock tool for Nforce3 250GB? that would be awesome if you can. =)
working perfectly!!
Ps: If i change with step at 1mhz when i press set it dosen't work!!
You have to increase 0,5Mhz to save the change
Lukija, could you do the same for ATI based mobo's?
Thanks again for all the hard work you put into these programs...
Fixed (I hope). Please re-download again.
@GenTarkin
If you can look in Sandra for something like PCI to ISA bridge, you will find something like VEN_10DE and DEV_00XX. A need that DEV_00XX info, because I do not have nF3 mobo. You wil find it under Buses and Devices section, it should be under Bus 0.
I do not think so. It is easier with nVidia since it generates clocks and not some specialized clock generator chip. I do not know if ATI has similar solution. If you find out, it can be done.Quote:
Originally Posted by Plywood99
It work perfect & precisely:woot:. Can't wait to see the A64Info with this new function. Clockgen will be history. Great job again lukija.:toast:Quote:
But it is funny that i can't open the nF4ClockTest together with A64Info. It say "Error loading driver".
works fine here with new A64Info v0.60 beta
http://www.fileshosts.com/DFI/NF4_SL...uz_idle_tn.png
http://www.fileshosts.com/DFI/NF4_SL...v060beta_1.png http://www.fileshosts.com/DFI/NF4_SL...v060beta_2.png
http://www.fileshosts.com/DFI/NF4_SL...v060beta_3.png http://www.fileshosts.com/DFI/NF4_SL...v060beta_4.png
thanks!
Unfortunately, this is because A64Info and nF4ClockTest use the same driver which has exclusive usage - only one of them can use it. I asked Audiofreak (guy who made driver) about that, and he is not planning to change it. That's why you cannot start more instances of A64Info either. But since clock change will be a part of A64Info , there should be no problems.Quote:
Originally Posted by RaMmElEe
Thank you for a wonderful tweaker! :clap:
All the features work flawlessly, and I have no complaints at all. I just thought I'd bring it to your attention that my Turion is not correctly identified. The original clock speed is 1.6 GHz, while both versions show 800 MHz.
230 % overclock on air? O' how I wish it was true :p:
works perfectly. awesome work :toast: :woot:
10x. Please download this tool:Quote:
Originally Posted by _damien_
http://avala.yubc.net/~lukija/cpuid.exe
and run it from prompt:
cpui > result.txt
You can zip result.txt and upload it here. It will help me to fix this issue.
Ok, I attached the .txt file :)
10x, this will help.
Small change, it should fix original multiplier detection. Please, redownload beta version again, it should detect properly original Turion multiplier. It works OK on my Opteron 165, I do not know about other CPU models. Here it is:
http://avala.yubc.net/~lukija/A64Info-beta.exe
Holy crap this is sweet. It works sooooo much better with my board.
Thanks!
lukija, could you change the version number of the application every time you make a change, no matter how big or small it is? For example, for a minor change, 0.61, 0.62, for a major change - 0.70, 0.80, 0.90, 1.0 Final etc. :banana:
Slight offtopic... Why did you lock the thread on the benchforum, where it all started? Now I have to monitor this forum daily, also. c c c c c :nono: :slap:
Any way, great app. Can't wait for NF4 Support within A64Info. Also, like many have suggested, a screenshot friendly GUI would be nice.
Keep up the excelent work :woot:
(Falcon@benchforum)
OK. Next version will have new number.
@OT
Bench forum is full of smartasses :with:. Audiofreak left it because of them. Why shouldn't I? I'm a member since it started its work, but now it is just a pale shade.
A little more offtopic, and no more from me, sorry...
If this "smartasses :with: " was meant for me, than I really have nothing else to say to you but thank you & :kissbutt:
No it wasn't.Quote:
Originally Posted by 3MAJ
