I plan on waiting until August 31st to start posting updates :p:Quote:
Originally Posted by [ZIZI]
... but honestly, I probably won't get started until june, too much to do this semester.
thanks :toast:Quote:
and about competition, some people posted they projects here, at Teampuss : http://teampuss.com/forums/index.php (in the middle of forum). check this out :)
Also what are rules concerning multiple units? Could I enter both co2 and open division?
Really I don`t know...but you should stay in one division, maybe next time you will enter open division ? but this is only my opinion, Runmc and Chilly1 should tell us they opinion.Quote:
Originally Posted by n00b 0f l337
Well I entered co2 due to a lack of gases, now I will have enough before september hopefully. I still want to attempt co2 though.
Starting my build this sunday :woot:
Going to pick up some ethane this weekend :D
Everyone's hitting up the ethane train? :( Damn there goes the advantage.
Yep :stick: :p:
It's because ethane has a low boiling point given the pressure which it condenses at, and has a decent latent heat of vaporization too.
Yup! :)
Originally Posted by gkiing
about time some one started the first autocascade hey gkiing.
200psi and autocascading at -20c :toast:
thats cheating:slapass:
cant wait to see some cold temps their gkiing.
havnt seen you for a while:D
im in for the open Class autocascade competition.
ill use 1hp r410 rotory, probably r507/r410-r1150
all parts will be here next week so im expecting the project to end within a month since im getting obsessed when competing :D
if the project turns to good temps it will be the first stage of my new 2stage cascade!
nice.Quote:
Originally Posted by esdee
thats going to be a beefy auto:toast:
Yeah, I haven't been around since about last september because of work, but now I have some time to build once again :woot:Quote:
Originally Posted by kayl
Yes the gas(es) came in!!! Now... how naive of me to think it would have more common fitting... now I have hydrogen regulator sitting here not being utilized (for ethylene tank)... time to search for CGA 660 fittings... and bunch of them... lovely.
Congrats ! :toast:Quote:
Originally Posted by jinu117
esdee --> you`re in !
sweet. the hydrogen regs fit 1150 bottles nicly. is the CGA 660 fitting for the refrigerant hose to screw onto, that was the only thing i had to change on mine. I got mine of oxygen reg not in use.
i have the impression we need to set some standards for out heat load testers.
like what resistors to use, same dimensions copper plate and same temprature measuring place
I find heatcartridge to be most efficient while others abide by resistor. And evap temp reading and inside load tester temp reading should be taken at same time really to see how well both side of story stacks up. (evap temp can be anywhere if we have set load tester temp measuring point really as we want cooler CPU even more than cooler evap :)
I am not really sure how this will unfold now with cryo-tek in there but hey not stopping :p
I personally don't see the point for the oil seps to be homemade, since those who will choose to buy a comercial oil sep will have no performance advantage in their autocascade!. how about we change this rule?
keep in mind that an oil sep will also act like a phase-sep
He hasn't yet officially thrown his hat in the ring, so no worries......for now ;)Quote:
yes this is possible too, but i was planning to pass through the oil sep only the 2nd stage gas, since first stage gas has no problem with oil carrying.Quote:
Originally Posted by Unknown_road
i like your idea...this would give lower static pressures too
Ok, we have 26 members...but ONLY 10 members gave me their ice bath shots ;]
I'm waiting on my thermometer, dt200 is being sent back, then buying echow's.
Okey, so other people please post your ice bath shots (if you can :D).
