cpu on water
with an ambient temp of 22°C i think
€:sry for my bad english :)
cpu on water
I just got a 3700+ SD from the same place SIOUX got his, but unfortunatly it insn't a KAB3E ;)
Here's the stepping:
KAB2E 0547 DPDW
1368887L50067
How do you guys think it will OC? :)
You might have written this, but exactly where did you buy the processor? Cause, we have SHG in Norway as well, and if they have it there ;)
And, how in hell did you get that water so damn cold? (Excuse the the casual profanity).
We bought it at http://www.shg.dk :)Quote:
Originally Posted by Big SturL
But I've heard that they don't have any KAB3E left...! Only KAB2E and KAB7E
netx weekend i'll try some more overclock with an ambient temp at ~0°C
last time i got with 1.6v 3321mhz pi stable
without ihs
Some KAB7E 0547 are pretty good actually --> 3.1GHz Primestable under water.Quote:
Originally Posted by Hype
i got my KAB7E running at 3100mhz prime stable @ 3200mhz havent tested it yet but it is running so far
but over 3100mhz it's getting hard with my kab7e
100mhz more without ihs and about 9°C less @ load
I would say KAB7E are even better than KAB3E... aren't they?
Originally Posted by Punisher!
After what i´v seen the KAB3E clocks a little better:)
http://img400.imageshack.us/img400/9...0mhz14v1ng.jpg
Danish:
SIOUX, jeg har skrevet en PM til dig på OC.dk :)
Kunne godt tænke mig at udveksle lidt detaljer med dig! hehe.
And i already wrote back to you:) I´m at work right now, but we will talk tomorrow:toast:
Oh okay :)
I havent' recived anything... But that's okay! As long as you know! :)
We'll talk tomorrow then!
EDIT:
But what do you guys think of my stepping? ;)
KAB2E 0547 DPDW
1368887L50067
SIOUX, if you want to get rid of that CPU..... :D
my 0547GPMW's..tested with air (TT BT) and an ambient temp of 17 degrees. With a DFI ofcourse;)
an 0001
http://i6.photobucket.com/albums/y237/BvK/56856345.jpg
an 0139
http://i6.photobucket.com/albums/y237/BvK/45745345.jpg
Nice cpu´s.
I recivid one of this yesterday but i have some problems.
Primming at 3000mhz 1.39v but 20min again the system crash, get freeze and can´t move the mouse. Then i need to restart.
Any idea?
dfi sli-dr expert 27/12
2x1gb gskill zx (orange slots)
sandiego 3700 (water cooling)
ocz ps 520w......
My CPU had some strange freezing to start with. So I gave it 1.45v in bios (DFI NF4 Ultra-D) and began to work with ram settings in BIOS/A64tw.Quote:
Originally Posted by ReviTK
Now prime95 24.14 stable at 3003 MHz on air.
Edit: Could be related to Max Async Latency and Read Preamble (to tight) and/or Vcore.
You need to tweak your memory + SuperPi man....Quote:
Originally Posted by SIOUX
Read the original post with the picture...Quote:
Originally Posted by 5days
It was NON tweaked...
SIOUX knows how to tweak, he's very good at it :)
- Nå ja, nu hvor i er ved det danske, SIOUX, søndag, senest, er der nye resultater oppe :D - Isolerede svineriet igår, håber ikke armaflextapen er strømledende, for i så fald er jeg på spanden :P
:lol: 5days telling SIOUX to tweak his memory :rolleyes:
Hehe, I tryed so once, and I was right, only one things wrong... It was a stability trick with his mem :P (tras = 0 is worse than tras = 5)Quote:
Originally Posted by dinos22
^^ I learned =)
I know that. :)Quote:
Originally Posted by M.Beier
I was merely asking him to do so I can see a proper 1M run - probably should have worded it better.
And here´s an SD3700 KAB7E0547GPAW
1380567L50079
11x277=3047Mhz on 1,408Vc without HS on Watercooling. Ambient was between
19-20,5C 33% Humidity 1006millibar Airpresure on 450m above Seaground.
TCAsemax=59°C
TDP=50Watts
http://img138.imageshack.us/img138/4...rime3aj.th.jpg
GPMW's on 3.0GHz..both exactly the same..even the temperatures. On 3.1GHz the temperature of the 0139 San Diego is 3 degrees lower, but on 3.0GHz they are the same..:confused:
0001
http://i6.photobucket.com/albums/y23...4675786796.jpg
0139
http://i6.photobucket.com/albums/y237/BvK/34646756.jpg
My old 0530APMW was a little better on 3.0GHz. But on 3.1GHz almost the same.
http://i6.photobucket.com/albums/y237/BvK/1.jpg
Originally Posted by Monge
At 1.47v prime run 8 hours last night. But this cpu was tested in other configuration and he do 3000mhz at 1.37v and 3100 at 1.45v (on air).
Why the system get freeze????
Plz help
Well, they have got some with the E6 stepping, I don't know how these overclock. Anyone care to give me a hint?Quote:
Here's a link to the shop BTW.
