We will need somone with two X1600XTs to try out dual slave cf on an RD580 to see if performance increases with more pci-e lanes.
Perkam
Perkam
where's the $110 x1600xt? :confused:
X1600XT 128MB GDDR3 5k 3dmark05: $110
http://www.newegg.com/Product/Produc...82E16814102667
Perkam
Good score if that's the score for it, but that's an x1600 PRO.
yeah dont see 5k anywhere for it :( think ddr3 might be a typo since the mem is running 780..
LOL Hopefully Newegg won't catch on just like everyone else :rolleyes:
http://www.sapphiretech.com/en/produ...s.php?gpid=133
All 128MB X1600 PROs are 1.4ns GDDR3. Since the only difference between an XT and a PRO is the difference in the memory bandwith arising from the DDR2 in the PRO and the GDDR3 in the XT, this is by all means an XT with 128MB...disguised as a PRO ;)
Perkam
perkam if I buy one and it's not gddr3 I'm suing you :slap: :p:
anyone tryin to overclock their 1600xt this site http://www.tweaktown.com/articles/835/ if you look at bottom they have a link to what they used to overclock it if link disappear or doesnt work pm me....
wow I wish my x1600xt clocked like that.
600/700 is pushing it, or seems.. atitool 0.25 beta 13.
that overclocker thing just made me crash...
i dont know works on my saphire x1600xt :confused:
i just pushed the X1600XT to 631/805 I think that is low.
I used the Overclocker Tool
they're supposed to...Quote:
Originally Posted by Willis
i have a x1600 pro saphire to test
i cant get mine to clock AT ALL...
Yeah I was able to get mine to 630/970 but the core wont go over that so it was of no use
i mean if I set 600/700 freelancer will crash....
was gonna buy the x1600pro 128, but got 2GB ram for 100 and I need a new hd :p:
@marioace:Can u give me a link to the overclocker tool you used?
Why is it that i can get mine to work more than 615 mhz in the core?
It crashes in the second test in 3dmark 05.
Can i use the overclocker tool to raise thr voltage?or it wont work?
6k done with $125 card !!! :banana:
Palit X1600Pro @ 752x1251 (Vgpu=1.76V) 128Mb DDR3 (Samsung 2.0ns)
Opteron 148 @ 2947MHz, 2*256 BH-5 @ 268MHz
Win2k SP4, Catalyst 6.2, DirectX 9.0c (Feb-2006)
Warm water @ CPU/GPU
2005=6067 3D Marks
http://img463.imageshack.us/img463/5...251opteron.png
EDIT:
2001=29552 3D Marks http://service.futuremark.com/compare?2k1=8899736
2003=10560 3D Marks http://service.futuremark.com/compare?2k3=4625261
Just first test more results soon...
Congrats man.My best so far is 5840 but with 615 core and 801 mem.
How did u raise the voltage of the core?Software or hardware mod?
Keep Going Man!:banana:
Pencil voltmod: http://www.vr-zone.com/index.php?i=3092&s=9Quote:
Palit X1600Pro no-Golden PCB looks a bit different than Palit X1600Pro Golden, but the same voltage controllers used.
Told you guys the 128mb x1600Pro's are XTs in disguise ;)Quote:
Originally Posted by S_A_V
Awesome results, SAV :up:
Perkam
10560 in '03 was at 685x1242 clocks...
New results with Vmem(Vdd) mod + more Vgpu:
2001: 30164 3dmarks, 752x1323 (Vgpu=1.81V, Vmem=2.04V)
http://service.futuremark.com/compare?2k1=8900200
2003: 11238 3dmarks, 752x1305 (Vgpu=1.81V, Vmem=2.04V)
http://service.futuremark.com/compare?2k3=4626155
2005: 6222 3dmarks, 783x1278 (Vgpu=1.84V, Vmem=2.05V)
http://service.futuremark.com/compare?3dm05=1810698
2006: not tested yet
Hope GPU will be benchable at 800MHz with cold water, I check it tomorrow...
With warm water GPU falls to blackscreen at 1.87V and 2d-unstable at 1.90V, but runs ok with 1.81V. Memory unlike voltage higher than 2.05... more voltage - more artifacts.
Palit made very nice card for that low price :)
