I tried the Vcca mod today by replacing the SMD resistor with a (regular) 1.2KOhm resistor.
I have a Celeron-M 350 (Dothan 13x100Mhz) CPU that wouldn't POST above 165FSB. Well, after the mod it still doesn't :(
Maybe I'm hitting the CPU's limit itself, even though it's cooled with a Zalman Cu7000 with silver grease. I'm thinking it should be able to go higher with this bastard..too bad the multiplier is locked in all directions, so I can't test 6x200..
Looking at the SMD resistor, I wonder if it's truly a 2KOhm? Did you guys measure it? I took a super-macro picture of it with my digicam and looked at that. Seems mine has a '8', something else, and an 'E' or 'F' stamped on it:
http://www.stack.nl/~brama/pics/smd.jpg
Not a very clear picture, thanks to the epoxy gunk :D
